F'ing Speaker Buzz in Door!!!
Old Mar 6, 2008 | 05:44 PM
logicbombx's Avatar
logicbombx
Default F'ing Speaker Buzz in Door!!!
I'm very **** when it comes to audio, I'm a recording engineer. I love my mustang but he passenger door speaker was buzzing so I decided to install new speakers. Guess what, It's still buzzing with the new speakers. I've taken the door apart about 4 times now. It's definitely something in the door vibrating and not a speaker or amp problem. Tried adding acoustic foam to different parts of the door but I've had very little luck in removing the buzz completely. Has anyone figured out how to get rid of the buzz? It is also present in the driver side door though it is not as bad. I don't have the shaker so I'm only talking about the speaker in the door. I'd appreciate any help if you can. Thanks!
P.S. I'm glad I installed the GT muffler so I can just turn the radio off and listen to my engine rev!!
Old Mar 6, 2008 | 06:33 PM
Fred Malibu's Avatar
Fred Malibu
Default RE: F'ing Speaker Buzz in Door!!!
check this..
That was (still is) my problem..
Whenever the music is loud I start to hear it..
Old Mar 6, 2008 | 06:46 PM
logicbombx's Avatar
logicbombx
ORIGINAL: Fred Malibu
check this..
Don't think It is that one, because I still heard the noise before I put that piece back on. But I'll double check. It felt like the noise was coming from near the speaker in the upper right corner. idk....
Old Mar 6, 2008 | 07:12 PM
MEK's Avatar
MEK
I just read a post about this the other day. Here it is:
https://mustangforums.com/m_4361483/tm.htm
And here is a TSB for door rattle/buzz:
http://www.2005stang.com/gallery/alb...m_door_pnl.pdf
I've had the buzzing once and while and it is annoying. Thought it was a speaker, but now I am thinking it may be oneof the issues listed in the TSB. I might try and tackle this one myself, the last time I had it at the dealer (for something else) they scratched up the plastic pretty good in several spots[:@].
Old Mar 6, 2008 | 07:16 PM
Mustang3GT07's Avatar
Mustang3GT07
I know it pisses me off to. I took mine to the dealer and they fixed it. Now i can blast the music as loud as i want with out hearing that stupid noise!
Old Mar 6, 2008 | 07:22 PM
logicbombx's Avatar
logicbombx
ORIGINAL: Mustang3GT07
Any idea what they did?
Old Mar 6, 2008 | 07:25 PM
Mustang3GT07
I believe they say they re-tightend the sub in the bottom passenger door and re-sealed the black plastic cover over it. Was all covered under warrenty and took them about a hr. They also did not damage or scrath anything like alot of people say the dealer does. I guess i got a good dealer.
Old Mar 6, 2008 | 07:28 PM
logicbombx's Avatar
logicbombx
Unfortunately I don't have the shaker system. So my buzz is coming from the door speaker. And I have a 2007 so I don't think the TSB helps me either.
Old Mar 6, 2008 | 07:31 PM
Mustang3GT07
I thought the shaker 500 came stock in all mustangs?
Old Mar 6, 2008 | 07:35 PM
moosestang's Avatar
moosestang
Place a piece of sticky foam on the back side of that plastic piece and your problem will be solved. To remove it just gently pry at a corner with a flat blade screw driver.
check this..
