Caster Camber Plates
Old Mar 7, 2008 | 12:38 PM
blike's Avatar
blike
Default Caster Camber Plates
I don't see these talked about a ton since most people just go with camber bolts if anything
What brand do you recommend / where is a good place to get them?
Old Mar 7, 2008 | 12:52 PM
Argonaut's Avatar
Argonaut
Default RE: Caster Camber Plates
I have the J&M Camber plates from lmperformance.com. The main other choices would be the Steeda HD plates or the Maximum Motorsports. MM are the most $ but they also adjust both camber and caster.
There is no 100% correct answer but for the most part street cars don't need them, the camber bolts will do the job of giving you adjustability (assuming you needit)at a fraction of the cost. I got them for the following reasons: a) track and autoX, b) solid upper mount, no chance of popping, c) I tend to overkill eveything.
Old Mar 7, 2008 | 12:59 PM
blike's Avatar
blike
Looking at americanmuscle, it looks like the J&M adjust both caster and camber, but it's only camber?
I was planning on going with the bolts, but during install I managed to overtorque one of the strut mount nuts and snapped it, so i need a new strut mount and figure why not
baddog671
Jul 26, 2016 01:20 PM
Explosive
Oct 2, 2015 07:45 AM
mdg
Oct 1, 2015 07:04 AM
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
