Spring Installation
Old Mar 10, 2008 | 09:52 AM
ODDYSEY's Avatar
ODDYSEY
Site Moderator of Fury!
Default Spring Installation
Should you get your car aligned after you install springs?
If yes, what about after you install sway bars, LCA's, panhard bar?
The reason I ask is because I plan on getting my springs done today, but here in the somewhat near future I am getting sways bars, and possibly LCA's & panhard bar, so I don't want to have to get it done twice.
Suggestions?
Old Mar 10, 2008 | 09:54 AM
ajaibr's Avatar
ajaibr
Default RE: Spring Installation
depends how much you're lowering it.... front springs or just rears? if you lower it more than an inch in the rear you should really get the pinion angle checked... if you're getting adjustable lca's you definitely need to get the angles checked in the rear....
157dB's Avatar
157dB
Cut & Paste Expert
Front, rear springs both?
Rear only, no alignment is needed.
Front springs, yes alignment.
ODDYSEY's Avatar
ODDYSEY
FRPP springs 1.5 inch drop. Can the alignment wait a few weeks?
Old Mar 10, 2008 | 09:59 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: ODDYSEY
No, you will haveway too muchtoe that will scrubb those fronts bald.
The bump steer will be scary at high speeds. Yor camber will also be
way out of spec and again, tire wear.
Old Mar 10, 2008 | 10:00 AM
ajaibr's Avatar
ajaibr
a couple weeks really won't hurt anything... a little odd tire wear and it won't feel right till you get it done is all...
Old Mar 10, 2008 | 10:13 AM
StowesStang's Avatar
StowesStang
ORIGINAL: ajaibr
Im running the same FRPP springs with the same drop, on 20" rims. I waited almost a month and didnt hurt anything. I do recommend camber bolts so they dont have to drill out. Camber bolts are only about $40 or so and you can order them online. You can have the alignment without camber bolts but with them they can get a more dead-on alignment. Ive had mine done without the bolts but next alignment will be with the bolts.
Old Mar 10, 2008 | 10:26 AM
ODDYSEY's Avatar
ODDYSEY
Cool thanks, I am having them align the car while im in there, better safe than sorry. I will work on the camber bolts etc when I do the rest of it.
Thanks for the advice everyone.
Old Mar 10, 2008 | 10:44 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: ODDYSEY
The camber bolts are part of the alignment procedure.
I would recommend having them when put in when
they align the front end or they will elongate the holes
to set the camber and then the bolts will be useless
with elongated holes, and on top of that, you will have
to pay for another alignment when you get the camber
bolts. [:@]
[IMG]local://upfiles/69445/FD75EF677EE043C3986944DC63993B62.jpg[/IMG]
Old Mar 10, 2008 | 11:06 AM
ODDYSEY's Avatar
ODDYSEY
Yea I told the them to go ahead and get the bolts when they did the alignment. Thanks
