Quick Torque Spec/UDPs
Old Mar 10, 2008 | 10:04 AM
ThumperMX113's Avatar
ThumperMX113
Default Quick Torque Spec/UDPs
What's the correct torque spec for the crank shaft pully bolt? I've got an instruction manual that says 37 ft lbs but that seems awfully low considering how tight the factory bolt was in there.
Old Mar 10, 2008 | 11:03 AM
TacoBill's Avatar
TacoBill
Default RE: Quick Torque Spec/UDPs
Torque in the write-up
How to: Install Steeda Underdrive Pulley
Old Mar 10, 2008 | 03:49 PM
Doc Holiday's Avatar
Doc Holiday
FIY:
I spoke with a tech at Steeda the other day while re-installing my UDP's, and he said that during the last step (turning the crank bolt an additional 90 degrees) you should set the torque wrench to 120 lb/ft and turn the bolt until the wrench "breaks" (clicks for the mechanically challenged, lol).
Ford specifies 115 lb/ft for the stock pulley. Steeda's old instructions said 37, then 90 degrees for the final torque, but apparently they're doing it different now, since the 90 degree method doesn't insure a specific torque and can vary quite a bit depending on who is measuring the 90 degrees, and also on the amount of stretch from bolt to bolt.
Old Mar 10, 2008 | 03:53 PM
ThumperMX113
Thanks for that.. I guess I'll have to go re tighten it.
Florida Regional Chapter
Sep 30, 2015 08:04 PM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
Sep 25, 2015 06:30 PM
