? on Roush Bumper Install
Old Mar 10, 2008 | 05:48 PM
GT06GT's Avatar
GT06GT
Default ? on Roush Bumper Install
Im 95% done installing the roush bumper, just need to put the wheel wells back in and I cant figure out (as stupid as it sounds) How to get those plastic push in clips to get back in there hole. Im talking about the ones with a plastic screw on the inside of them, and then 4 posts that stick out the other end. I tried pushing them in, but they wiggle around and dont "snap" in like they did before. Anyone who has done this before pls chime in, Its the same ones u remove if your installing clear corners or changing your lower light baulbs.
Also, I decided id rather have all 6 lights on the bumper at once then my pick of either or, So I cut apart the wiring harness and eliminated the relay roush put in, My lights work fine and all, but the Stock fogs, and roush fogs are a little bit dimmer then the stock ones were before, more yellow vs white. If I double the amps on the fuse for the stock fog lights do you think this will get more power to the lights? or does anyone have a better idea, short of running there own seperate power line.
Old Mar 10, 2008 | 06:02 PM
GT06GT's Avatar
GT06GT
Default RE: ? on Roush Bumper Install
finished my beer break, im goin back outside to have another attempt at it, hopefully someone can chime in with some past experience
Ill have pics of the completed car up later
Old Mar 10, 2008 | 06:22 PM
Fred Malibu's Avatar
Fred Malibu
..You mean the fender liner screws?
They screw in.
A twist to the right will put them back in place.
(I feel like that's not the thing you are talking about, but its the best I got for ya [8D])
Old Mar 10, 2008 | 07:23 PM
GT06GT's Avatar
GT06GT
not the ones that connect the facia to the guard, but the ones that actually connect the guard to the frame of the mustang itself. Thanks anyways though =)
mtgldr
Feb 3, 2024 09:00 PM
TimeLord101
Sep 4, 2015 09:27 AM
