Question about trunk release
Old Apr 8, 2005 | 11:51 AM
Nebfan's Avatar
Nebfan
Default Question about trunk release
Has anyone else noticed there isn't a trunk release from inside the car. If you don't have the keys, you can't relese the trunk from inside the car. I hope I just haven't found the release yet. If Ford didn't put one in the cars, then that is stupid. Hopefully I am the one who is stupid.
Old Apr 8, 2005 | 11:58 AM
Hydra8572's Avatar
Hydra8572
Default RE: Question about trunk release
There is no trunk release, except on the key fob.
Old Apr 8, 2005 | 12:04 PM
hawgman's Avatar
hawgman
I ♥ Acer
Well, technically you could fold down the rear seats, crawl in to the trunk, and pull the saftey release
Old Apr 8, 2005 | 12:07 PM
Hydra8572's Avatar
Hydra8572
Do the rear seats fold down?
Old Apr 8, 2005 | 12:08 PM
algregory's Avatar
algregory
Ford apparently did all they could do to make the car affordable (Thank You Ford!) I assume that if you are inside the car, you have your key with you? Walla! An inside the car trunk release!
ORIGINAL: Nebfan
crawz's Avatar
crawz
No release from inside the car isn't a bad thing. Think extra security from someone popping your trunk internally and stealing your 2000 dollar system.
Old Apr 8, 2005 | 12:42 PM
afixer's Avatar
afixer
what you ca do if you want is to at a botton to trip the relay for the trunk. the loom is on the pass side at the smart juntion box. it is a ground the white/violet wire goes from behind the juntion box to the fuse panel under the hood. so you can splice into it if you want run to a switch anywhere and ground from the switch. i hope this helps i guess also if you would rather use a hot wire you could splice in the the wire going to the latch pink /orange its under the door sill pass side
[IMG]local://upfiles/14019/9ACB7E47AC00492A8513A3D8A13187D9.jpg[/IMG]
[IMG]local://upfiles/14019/FDF631074A8F41F099C9A7A8CED7A358.jpg[/IMG]
Old Apr 8, 2005 | 04:02 PM
Professor Wizard's Avatar
Professor Wizard
MF Moderator
Afixer...
NICE... THANKS...
I saved all that on my drive for future reference... I will be installing my own "Trunk Release Button".
Old Apr 8, 2005 | 04:55 PM
Nebfan's Avatar
Nebfan
ORIGINAL: afixer
Do you think that Ford would do it since I am not a fixer at all. If not, who could do it?
Old Apr 8, 2005 | 05:27 PM
05SatinSilver's Avatar
05SatinSilver
Why not save all the hassles of wiring and just buy another remote? Go out on ebay and get a new one for $20. You can program the new remote to work with your car. Then, just keep it in the arm-rest or glove box. Either loose, or velcro it inside somewhere. You'll only need to replace the battery about every 18-24 months! Easy trunk button!
Dave...
