Whats it called?
Old Mar 15, 2008 | 10:10 AM
fastmxer9's Avatar
fastmxer9
Default Whats it called?
The plastic pieces around the windows on the exterior? and how do replace them, are they stickied on?
Old Mar 15, 2008 | 10:46 AM
157dB's Avatar
157dB
Cut & Paste Expert
Default RE: Whats it called?
The front windshield trim is applied before the windshield is installed.
It is stuck on with adhesive.
http://iihs.net/fsm/?dir=458&viewfil...ld%20Glass.pdf
I think the rear trim is the same.
http://iihs.net/fsm/?dir=458&viewfil...***%20Rear.pdf
Old Mar 15, 2008 | 10:49 AM
fastmxer9's Avatar
fastmxer9
my bad i didnt make it clear. I'm talking about the driver and passenger side windows.
Old Mar 15, 2008 | 11:57 AM
157dB's Avatar
157dB
Cut & Paste Expert
Door window weatherstrip?
Not sure how its held on.
Old Mar 15, 2008 | 12:03 PM
fastmxer9's Avatar
fastmxer9
possibly. mine are looking a little shabby and fadded so i want them off. it looks like there is a like a double sided tape kind of thing underneath, but i dont wanna experiment with anything cosmetical until i know for sure.
Old Mar 15, 2008 | 12:37 PM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: fastmxer9
Dont attempt it. There are foam seals under there also.
Get some of that back to black plastic dressing.
Old Mar 15, 2008 | 01:56 PM
fastmxer9's Avatar
fastmxer9
[:-] not the answer i wanted to hear but better to know that before I go tearing it apart and creating a real problem
Old Mar 15, 2008 | 02:01 PM
DeStonn's Avatar
DeStonn
Why are they looking shabby and faded on an 06? +1 on the back to black or even armour all will help.
Old Mar 15, 2008 | 02:10 PM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: DeStonn
BIG negative on the armourall. [:@]
Thats probably why they look bad.
Someone at the dealership must
have armouralled them. Did ya buy
it new or used. Used are usually armouralled
and look good for a while but then more
armourall is needed and the cycle begins.
Good, bad, armourall, good, bad, armourall. [:'(]
Old Mar 15, 2008 | 02:12 PM
Johnboy7701's Avatar
Johnboy7701
+1, back to black makes things look all better...
