Correct wheel offset
Old Mar 15, 2008 | 02:10 PM
smythge's Avatar
smythge
Default Correct wheel offset
Is the correct offset for 05+ mustang wheels 40mm? I am looking at set of Shelby razors and they are offered in 24mm and 40mm.
Old Mar 15, 2008 | 02:25 PM
rshamekh's Avatar
rshamekh
Default RE: Correct wheel offset
The correct offset is 45mm I guess.
If I were to get the razors, I'd get them in 24mm offset, because they stick out more, it looks nice.
Old Mar 15, 2008 | 02:29 PM
157dB's Avatar
157dB
Cut & Paste Expert
16x7 OEM 35mm offset
17x8 OEM45mm offset
18x8.5 OEM 50mm offset
offset required is relative to the rim width
Old Mar 15, 2008 | 02:34 PM
smythge's Avatar
smythge
ORIGINAL: 157db
17x8 OEM40mm offset
Very helpful, thanks!
Old Mar 15, 2008 | 03:02 PM
ohnoesaz's Avatar
ohnoesaz
Keep in mind that the official offset doesnt look as good as the other offset of older mustangs, around 24mm... but do some searching and make your decision.
Old Mar 15, 2008 | 03:31 PM
ODDYSEY's Avatar
ODDYSEY
Site Moderator of Fury!
I am running razors with a 24 and 40 mm offset staggered. Click signature for pictures.
Old Mar 15, 2008 | 04:12 PM
fairlane292's Avatar
fairlane292
ORIGINAL: 157db
17x8 OEM40mm offset
OEM 17 bullits are actually 45mm (not 40mm)
[ul]M-1007-T178S*[*]Fits 2005-08 Mustang GT[*]5-Lug 4.5" bolt circle[*]6.295" backspacing[*]45 mm offset[*]17" x 8" wide[*]Includes center cap[/ul]
Old Mar 15, 2008 | 04:29 PM
Flatline1980's Avatar
Flatline1980
My 18x10 Roush are offset by 41mm
Old Mar 15, 2008 | 04:41 PM
ApexStang's Avatar
ApexStang
I bought AR Torque Thrust M Shelby Editions and the shop accidentally ordered the 24mm offset. They looked terrible! I had 18x9 Front and 18x10 Rear. They stuck out at least an inch outside the fender. Looked like GARBAGE. Called them out on it and they reordered the 40+ offset and all is good now.
Old Mar 15, 2008 | 04:59 PM
2007REDFIREGT's Avatar
2007REDFIREGT
On the 20x9 razors you can use the 24 or 40 offset. 24 offset will put the rim/tire just outside your wheelwell and the 40 offset will tuck rim/tire just inside the wheelwell. I have the 40 offset, looks better to me, but's thats your choice. Sorryno pictures computor problems.
