T/B Cleaner??
Old Mar 19, 2008 | 07:33 PM
Bluestar's Avatar
Bluestar
Default T/B Cleaner??
What Brand do you use? Did you notice any improvement after cleaning?
Old Mar 19, 2008 | 07:50 PM
mlcrycc's Avatar
mlcrycc
Default RE: T/B Cleaner??
I used STP cleaner, and definately noticed a difference. Specifically, when leaving in first gear, major smoother engagement, and smoother idle.....
Old Mar 19, 2008 | 08:02 PM
Bluestar's Avatar
Bluestar
Thanks Mike, I pick some up in the AM.
rshamekh's Avatar
rshamekh
I cleaned mine when I had a rough idle. It didn't really help at all so I just let the dealership replace mine under warranty, and I had the CAI on. I just told them not to reset the pcm. Great dealer... I guess i'm lucky...
Old Mar 19, 2008 | 08:05 PM
Bluestar's Avatar
Bluestar
Sometimes....Not always, a rough Idle can becaused bya Dirty Fuel Filter.
Old Mar 19, 2008 | 08:09 PM
rshamekh's Avatar
rshamekh
Could be... but replacing the TB really helped with my rough idle.. it became soo smooth...
Old Mar 19, 2008 | 08:17 PM
NVRL8's Avatar
NVRL8
Do you have to remove the throttle body to clean it ?
Old Mar 19, 2008 | 09:32 PM
mlcrycc's Avatar
mlcrycc
ORIGINAL: NVRL8
Nope, cleaned it in place....This was the result.....
[IMG]local://upfiles/13557/BE11E5DFE5FC424A8E45B460742D628C.jpg[/IMG]
[IMG]local://upfiles/13557/05AC1C08EF8E4C629CE4D6831B639625.jpg[/IMG]
Old Mar 19, 2008 | 09:41 PM
ShadyNinja's Avatar
ShadyNinja
wow Dirrty
I think Ill clean mine
I want to clean the mass air sensortoo (due to the olied air filter)but I think the throttle bottle cleaner is a nono for the sensor
Old Mar 20, 2008 | 02:11 AM
olvanish's Avatar
olvanish
ORIGINAL: ShadyNinja
wow Dirrty
It is a no no. CRC makes an electronic connector cleaner or an electric parts cleaner would also work I believe (made by the same company)
