Car Overhreated! Need HELP
Old Mar 20, 2008 | 03:25 PM
99flhr's Avatar
99flhr
Default RE: Car Overhreated! Need HELP
ORIGINAL: SeanoStang
yeah def a bad thermostat
Well there you go, in "internet auto diagnosis" there are very few "defs". But, there are frequently more than one "possibles"
Old Mar 20, 2008 | 03:31 PM
moosestang's Avatar
moosestang
Yep. the fans cool the radiator when idling. They will come on around 215-220 and they cool it off surprisingly quick. If The fan isn't working then it will overheat.
Old Mar 20, 2008 | 03:41 PM
pascal's Avatar
pascal
S197 Section Modder-ator
I agree... I'm a big fan of those.
Especially here in FL, during summer time[&:].
Old Mar 20, 2008 | 03:52 PM
ohnoesaz's Avatar
ohnoesaz
So how does a bad fan affect air conditioning? I thought only a belt belt problem could affect coolant and a/c.
But Ill shutup.
Old Mar 20, 2008 | 03:59 PM
99flhr's Avatar
99flhr
ORIGINAL: ohnoesaz
But Ill shutup.
The A/C condenser is a radiator and it`s mounted in front of the coolant radiator. It depends on differential temperature to shed heat and return the refrigerant to gas ( or is that liquid?)
When there is no air flow because the the fans are kaput, and the rad behind it is boilinghotit can no longer maintain the cooling to the degree you expect. A/C vents no longer blow air that`s "cold" Simple really.
Old Mar 20, 2008 | 04:26 PM
MUSTANGLOVER73's Avatar
MUSTANGLOVER73
was it a bad fan or did a relay go bad to cause the fan not to come on?
Old Mar 20, 2008 | 04:29 PM
Kara's Avatar
Kara
The day I drove my stang home which was 300 miles, it got HOT!!!! Hasnt since though! I was very concerned about this, however I have not had this problem again.
Old Mar 20, 2008 | 05:14 PM
ohnoesaz's Avatar
ohnoesaz
ORIGINAL: Kara
Judging by your sig pic I dont think you have anything to worry about
Old Mar 20, 2008 | 07:49 PM
TorchRed04GT's Avatar
TorchRed04GT
Finally got the car back today and all seems to be ok. The dealership took really good care of me and they even took care of the airbag recall as well. Thanks for the help guys.
Old Mar 20, 2008 | 07:59 PM
dmhines's Avatar
dmhines
So what do I win? I was the first to say FAN .....
djbigskrilla
Sep 20, 2022 01:04 AM
chain
Aug 17, 2015 08:52 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
ccwebb
Aug 11, 2015 06:47 PM
