Storing the pony.
Old Mar 21, 2008 | 05:23 AM
Menace's Avatar
Menace
Default Storing the pony.
Hey guys, I won't be driving the car for 5+ months. I'll have someone that can start the car every so often to make sure the battery stays alive; but what else should I do to prevent anything from getting nasty?
Should I have little to no gas in the tank, or a full tank with some type of additive to prevent it from going bad? Should I change the oil just before I go? Stuff like this is something I don't have any knowledge on so hopefully some of you guys can fill me in.
Old Mar 21, 2008 | 05:33 AM
99flhr's Avatar
99flhr
Default RE: Storing the pony.
Full gas tank with Sta-bil added
Fresh oil change
Battery tender installed
Air up tires to 50 psi
Park it, don`t start it
There are eleventy seven posts on this question,
Search function is your friend
Old Mar 21, 2008 | 05:47 AM
Menace's Avatar
Menace
I'll be honest... I think the search function is garbage.
Old Mar 21, 2008 | 06:25 AM
99flhr's Avatar
99flhr
ORIGINAL: Menace
Don`t disagree, although, the last few times I`ve tried it, seems to be improved. Most times it seems to have PMS
Old Mar 21, 2008 | 08:07 AM
07MustangGT_girl's Avatar
07MustangGT_girl
Get a battery maintainer for it (as long has you have power in the garage that is)
Old Mar 21, 2008 | 11:27 AM
BAMFstang's Avatar
BAMFstang
Everyone has their own preferred methods.
When I put mine away for the winter, I simply fill it up, park it and cover it. Nothing extra is done and every spring when I get in it it fires up right away, runs perfect and doesn't even lose any tire pressure.
Now if the car were a few years older that might not work as well but in the cars first few years of life, it has been perfectly fine for me.
Old Mar 21, 2008 | 11:31 AM
Riptide's Avatar
Riptide
I've always heard that if it's going to be over a few months or so without even a short drive you might want to drain the oil out of the car, put some fuel stabilizer in there, and put it up on blocks.
Old Mar 21, 2008 | 11:37 AM
madmike's Avatar
madmike
I agree, the search mal-function bites it.
mynameismike65's Avatar
mynameismike65
Mines been sitting for almost 5 months now[:@].....I have a 1/4 tank of gas in it (forgot to fill it up[&:]).......the same oil that was in it over the last summer (2,000 miles) and no additives. I have started it once a month and let it run for about 10-15 minutes. Every time I start it it starts right up and runs beautifully......I never had a battery issue.
Old Mar 21, 2008 | 11:50 AM
exx1976's Avatar
exx1976
+1 on search [mal]function.
Another decent idea when storing it for that long is to put steel wool in the tailpipes to prevent mice from making a home in your exhaust..
And put mousetraps on the floor in the interior, just incase one gets in there, so they don't eat your seats.
If you're storing it in a wet/humid climate, a pan or two of kitty litter under the car to absorb moisture is also a good idea.
And definitely cover it.
