Someone with indash 2din nav... please help
Old Mar 26, 2008 | 11:55 AM
JSP2005's Avatar
JSP2005
Default RE: Someone with indash 2din nav... please help
ORIGINAL: BigFloppy
Just take your time, it'll be worth it!
Decide if you're going to go full stealth (hiding your NAV antenna under dash / rear compartment)
Are you getting Sirius or Xm to go with it cause it would be easier to install all at once rather than having to take everything out to install those as well
Personally, I've got BOTH my XM and Sirius receiver boxes behind the rear-seat, the Blue-Tooth adapter is hidden beneath the center colsole (at the side of the cup-holders)
You'll definitely enjoy the Z2!
OH yeah, don;t forget to do the "bypass" as listed here.... http://www.sminntech.com/z1flash.html#newbypass
That looks great! Where did you install the antennas for nav and sat. radio?
Old Mar 26, 2008 | 11:59 AM
BigFloppy's Avatar
BigFloppy
I didn't hide mine.... You can clearly see all 3 warts on the rear yellow trunk stripe
REMEMBER, if you get tints installed GO WITH NON-METALLIC or you won;t be able to hide the antennas very effectively inside the car (You'll lose reception)
Old Mar 26, 2008 | 01:14 PM
MustangChris04's Avatar
MustangChris04
I have an 08 gt
So all I need is a?:
antenna adapter
wiring harness
voltage regulator
Does anybody have part numbers for these or where I can get them at a good price?
Old Mar 26, 2008 | 01:24 PM
BigFloppy's Avatar
BigFloppy
you're going to need a mounting kit for the Nav unit as well
Circuit City for the Antenna, Wiring Herness, Mounting Kit
Radio Shack for 5V regulater / resistor
Old Mar 26, 2008 | 01:49 PM
GuitarGuyBMG's Avatar
GuitarGuyBMG
Does the one from crutchfield fit as well as the one from circut city?
Old Mar 26, 2008 | 01:59 PM
BigFloppy's Avatar
BigFloppy
You'll probably find that the one from CircuitCity doesn't come with the BASS outputs (you'd have to ask them for hat one separately)... at least that what it was 3 years ago
The one from Crutchfield comes 100% complete
Old Mar 26, 2008 | 03:56 PM
noonyb's Avatar
noonyb
I have a Z2 in my F150. I put the GPS antenna under the front dash in the cab. I dont have any trouble getting a signal. XM will need clear line of site.
jlp66stang
Jan 1, 2008 10:40 AM
BuddaBing
Jul 15, 2007 06:49 AM
babbrstang
May 30, 2007 02:34 PM
FredTT
Mar 12, 2007 08:49 PM
luckydawg003
14
Jan 7, 2007 04:56 PM
