Check Engine light after a jump?
Old Mar 27, 2008 | 12:58 PM
stangboy555's Avatar
stangboy555
Default Check Engine light after a jump?
Had a dead battery the other day (Don't ask), so I got a battery charger from a buddy.. that took too long and we decided to jump it. Now the Check Engine light is on.. did I fry something? It's an 07 stick.
Old Mar 27, 2008 | 02:25 PM
hammeron's Avatar
hammeron
Default RE: Check Engine light after a jump?
check the trouble code and let
us know what it is
it may be alternator related
Old Mar 27, 2008 | 02:26 PM
modaddict's Avatar
modaddict
Ditto - the code will tell all...
Old Mar 27, 2008 | 02:30 PM
MustangChris04's Avatar
MustangChris04
that happened to me but the light went off shortly. maybe drive around to charge the battery and then unplug the battery and let it sit for a few minutes and then start it up...
Old Mar 27, 2008 | 03:42 PM
stangboy555
I'm gonna go unplug it for a couple minutes.. how do I get the trouble code?
Old Mar 27, 2008 | 04:12 PM
cadillo's Avatar
cadillo
ORIGINAL: hammeron
us know what it is
How does one get the car to give us these codes?
Old Mar 27, 2008 | 05:01 PM
157dB's Avatar
157dB
Cut & Paste Expert
With a code reader.
A Diablo tuner or an MSD DashHawk or something like an
Equiss code reader or AutoZone can pull the code?
The days of shorting two wires on the ODBII connector and
counting the check engine light flashes are over. [:@]
Old Mar 27, 2008 | 08:19 PM
alz's Avatar
alz
Auto Zone around here will read your codes for you and reset them. You may have to wait a bit until they aren't busy. They do it hoping to sell you parts.
Al
Old Mar 27, 2008 | 08:21 PM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
It's most likely a code in the ABS module for low battery voltage. Nothing major.
Old Mar 28, 2008 | 09:13 AM
stangboy555
Unplugging it for a few minutes worked.. I disconnected the NEG terminal for about 20 minutes and the light went away after I plugged it back in. *Whew!*
