Dspec install ? ASAP!
Old Mar 27, 2008 | 05:46 PM
Stoenr's Avatar
Stoenr
Default Dspec install ? ASAP!
Do you resuse thebumpstopfrom the old strut? Yellow mushroom thing on the stock struts
Plus what about the dust boots. The factory one has a metal washer at the top. Dspec dust boot does not and is wide open.
Old Mar 27, 2008 | 05:57 PM
leepinlen's Avatar
leepinlen
Default RE: Dspec install ? ASAP!
I used the stock stops but left out the dust boots
Old Mar 27, 2008 | 06:07 PM
Stoenr's Avatar
Stoenr
No dust boot at all?
Old Mar 27, 2008 | 06:13 PM
cobraa99's Avatar
cobraa99
i used stock stops as per instructions and provided dust boot
Old Mar 27, 2008 | 06:52 PM
miloman's Avatar
miloman
Your D-specs came with a new dust boot? Mine didn't.
Then again, they didn't come with the nuts to bolt them into the car either.
Old Mar 27, 2008 | 07:16 PM
cobraa99's Avatar
cobraa99
oh yeh there shorter than stock..funny thing they sent an xtra set in mine...if they shorted you ill be more than happy to send you my extra
Old Mar 27, 2008 | 09:32 PM
Stoenr's Avatar
Stoenr
Well I went with the OE dust boots. Look alot better than the Dspec ones
I removed the bumpstops.
I did not get any install instructions with mine, oh well, who reads those anyway!
Went great, no issues, love it. Snowed today of all days so could not test em out.
The Strut mount that is replaced in the TSB took care of the chuckle/klunk over bumps too!
Old Mar 27, 2008 | 09:33 PM
Stoenr's Avatar
Stoenr
ORIGINAL: miloman
The only bolt they should have came with is the top bolt on the shaft.
Old Mar 27, 2008 | 10:04 PM
miloman's Avatar
miloman
The set I bought had nothing. I got struts....that's it. No nut, no dust boot, no bump stop, just a strut. The shocks at least had the new rubber and nut. I just used the stock bump stop and dust boot, and had to go to R&E Fasteners here in Reno to get the nuts. They didn't have a flanged nylock 14mm x 1.5mm, but the Steeda strut mounts have a pretty thick washer on top, so I didn't really see the purpose for a flanged nut.
mtgldr
Feb 3, 2024 09:00 PM
Nick Oliver
Oct 17, 2018 04:22 AM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
