Is fuel filter a DIY job?
I noticed that according to maintenance schedule, my fuel filter is due to be replaced.
Is that a job that's relatively simple to do yourself...or best left to dealer/shop to do? Where is it located? Anybody out there done this? |
RE: Is fuel filter a DIY job?
It's really easy can be done yourself, I know there has been a lot of threads created. If you scroll down to the bottom of your thread you will see related threads. try those or try the search good luck.
I'm new to ford CARS, but on all my past (ford)trucks you have to have a special wrench/tool is this the same on mustangs?
No it's the push clamps very easy to do.
There were instructions posted on how to do it before. I remember somethinga about starting the car with the fuel pump relay removed and let it stall on it's own that way most of the fuel will be out of the lines when you disconnect them.
Take off plastic cover under car, located under driver's seat area. Once you get that off then the fuel filter is sitting right there in front of you. Unclip each end and slide it out. Slide new one in. Bolt plastic cover back on.
I knew it was somewhere with good pictures but was hoping he would take the time to search since I'm sure he will have other questions that can be answered by using the search feature!
Mine probably needs replacing soon too...
Excellent! thx
