speedo?
Old Mar 31, 2008 | 09:38 PM
05gtgreen's Avatar
05gtgreen
Default speedo?
I just finished installing the "mycolor" instrument cluster in my 05 mustang and the speedo seems to be 5km/h out. Is it out that much through all the speeds. When the car is parked the speedo sits a little above the 0km/h. I was wondering if this is goin to affect my milage on my odometer at all? I assume it is out this much because I used a gps on the highway to see how accurt the speedo was. Also, is there any way to reset the speedo so it reads correctly. Thanks.
Old Mar 31, 2008 | 09:54 PM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: speedo?
take it apart and move the needle.........
Old Mar 31, 2008 | 10:13 PM
05gtgreen's Avatar
05gtgreen
Default RE: speedo?
isn't that face shield glued on to the cluster? All I really want to know is if it is goin to affect my odometer at all. Cause if it is not, then I will just leave it. probably save me a couple speeding tickets, lol.
Old Mar 31, 2008 | 10:17 PM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: speedo?
no its not glued.....takes 10 minutes to fix
Old Mar 31, 2008 | 11:20 PM
05gtgreen's Avatar
05gtgreen
Default RE: speedo?
I almost forget, now when I put the car in reverse the dash beeps. It makes the same noise and when you have the e-brake on. Is this normal?
Old Mar 31, 2008 | 11:54 PM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: speedo?
it will also beep at 75 MPH
you need to have it programmed with the "as Built" data at the dealer
Old Apr 1, 2008 | 11:36 AM
05nightrider's Avatar
05nightrider
Default RE: speedo?
im looking to replace my cluster but want to know how to remove the dash so i dont break anything.. how hard is it to do?
Old Apr 1, 2008 | 09:22 PM
05gtgreen's Avatar
05gtgreen
Default RE: speedo?
its actually pretty easy. The dash piece just pulls right out, and there is four screws holding the cluster in place. Just one plug behind the cluster, with plenty of wire to work with.
Old Apr 2, 2008 | 05:39 PM
05gtgreen's Avatar
05gtgreen
Default RE: speedo?
When I take my car into the shop to get them to put in the "as built" data, can they do this with my current brenspeed tune in the car already?
Old Apr 2, 2008 | 05:52 PM
MustangChris04's Avatar
MustangChris04
Default RE: speedo?
I believe it has nothing to do with the tune. I think they program the actual computer in the cluster??
