Sequential Tail Lights
Old Apr 4, 2008 | 08:30 AM
  #21
157dB's Avatar
157dB
Cut & Paste Expert
Default RE: Sequential Tail Lights
ORIGINAL: birdoffire7
I have the CDC dynamite sticks. Intalled myself, super easy (even while on vacation at brother's house with very little tools).
+1
CDC Dynamite Sticks.
Easy on the bulbs.
Leagues ahead of the compitition.
"Promoting turn signal use one customer at a time".
Old Apr 4, 2008 | 09:18 AM
  #22
Leoleo's Avatar
Leoleo
+1 on the plug and play!!!!!Works great.
Old Apr 4, 2008 | 09:34 AM
  #23
Burnsy's Avatar
Burnsy
ORIGINAL: Larmo
Burnsy... I want the chase kit as well. Tell us more about the install. It looks intimidating, especially compared to the plug & play kits available.
Well you can download the install doc off of his website at www.meter4it.com but the install is not that bad. Just take your time. I soldered and heatshrinked everything, which I reccomend to everyone. Soldering is not hard at all. Watch a couple videos on youtube and honestly you are set.
I only used his connectors that he sends in the kit 3 or 4 times, and they were all T-taps, because they looked like they would hold well and I didn't feel like soldering into the middle of a wire if I didn't have to.
If you use his scotch-locks, they will work, but someday they will fail. Soldering/Heatshrinking is the way to go without question and it is EASY!
The install took me an hour and a half (going very slowly, heatshrinking everthing) and that also included removal and re-installation of the panels as well as cleaning out my trunk.
If you don't have a friend that is good at wiring, then just take your time. Go to radio shack, get a soldering iron, solder, heat shrink, wire stripper, and a crimper just incase you need to use a connector of his.
Honestly it is not hard, but it does look hard.
Old Apr 4, 2008 | 03:36 PM
  #24
kdrshocker's Avatar
kdrshocker
+1 meter4it
love the chase function, i have never changed it back. I get tons of compliments on them all the time and it was a breeze to install.
Old Apr 4, 2008 | 03:42 PM
  #25
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
Ive posted this befor like 1587549623 times, but here it goes again. Great price and quality:
www.mustangtaillightsequencers.com
Old Apr 4, 2008 | 04:51 PM
  #26
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: kdrshocker
+1 meter4it
Iget tons of compliments on them all the time and it
If you go with the meter4it kit, please dont use the
red IDC (insulation displacementconnectors) Scotchlock
wire connectors they supply. Give your stang the respect
it deserves and use solder and two stage heat shrink on
all connections as the factory did.
Otherwise you are setting someone up for taillight problems in the future. []
[IMG]local://upfiles/69445/CE6B605D70384310BCA2236C58B9739B.jpg[/IMG]
Old Apr 4, 2008 | 07:17 PM
  #27
deekum1627's Avatar
deekum1627
+1 to meter4it.com i want them
Old Apr 4, 2008 | 07:25 PM
  #28
Burnsy's Avatar
Burnsy
ORIGINAL: 157db
you think so huh?
those are the ONLY scotchlocks I used... There wasn't much wire there and they looked like they were pretty solid to me... Why do you see these as weaker than the others?
Old Apr 4, 2008 | 07:40 PM
  #29
mlcrycc's Avatar
mlcrycc
If your 05 or 06 has an early build date, this looks like a pretty darn good deal. Haven't picked up a set yet, keep meaning to, but.....well, you know.....
http://www.gtconcepts.net/mustang/0506.htm
Old Apr 4, 2008 | 08:56 PM
  #30
washamur's Avatar
washamur
ORIGINAL: mlcrycc
Got these in the mail today ... but I think I may have ordered the wrong ones.
Checked my Date on the door plate and it says: 05/06
Does this mean May of '06 - or - June of '05?
I didn't know there was a difference ... and hoping they will work.
