Roush Shift Ball
Old Apr 4, 2008 | 11:48 PM
StickShifty's Avatar
StickShifty
Default Roush Shift Ball
Does the Roush shift ball, come with the little metal collar to connects the bottoom of the ball to the shift boot?? so you do not see the stock metal shifter. Click the link for a picture.
http://www.americanmuscle.com/roush-...***-white.html
Old Apr 5, 2008 | 12:01 AM
thewarmachine's Avatar
thewarmachine
Default RE: Roush Shift Ball
I think so. Someone on here has it and made a post one time about how to get it together with the boot.
Old Apr 5, 2008 | 07:01 AM
DarkFireGT's Avatar
DarkFireGT
It has a black collar that the boot slides over. On one side it has a small tube that extends up to the ****. The problem is, nothing keeps that collar up. When I had it, I ended up turning the collar over and taping it to the stick. Then used a metal threaded spacer I made, to keep the **** in place. You'll see that in the customers pictures on AM's site in the link above. Ultimately, I bought a nice adapter from GrabberPony.com that had threads built in. I think I've got pictures of the progression.
How it's intended for install from Roush. This will work fine if you wrap electric tape around the shaft under the boot adapter, to keep it in place.
After adding the threaded spacer I made.
After the grabberpony.com adapter
Of course, shortly after all of this, I got my Hurst.
Old Apr 5, 2008 | 07:04 AM
DJStile's Avatar
DJStile
I tried a few ways to make it work how it came, but just save yourself the time and get the adapter from Grabberpony.com. Here is the link,select the 12mm x 1.25 and frosted finish if you want it to match the interior upgrade package (if you have it, that is).
Good luck!
PaulH2
20
Jan 31, 2016 09:48 AM
Thunderball
15
Nov 22, 2015 11:49 PM
Explosive
Oct 2, 2015 07:45 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
Sep 30, 2015 12:39 PM
