paintless dent removal?
Old Apr 8, 2008 | 01:13 PM
bcstang's Avatar
bcstang
Default paintless dent removal?
hey guys, i have a question. i walked out to the car yesterday and found a dent over my back right side wheel well. i took it in and the guy at the shop said it would be 500 bucks to knock out the dent and repaint the panel. should i do that? or have any of you guys tried paintless dent removal, whats involved in it and does it really work?
Old Apr 8, 2008 | 01:15 PM
RojoDojo's Avatar
RojoDojo
Default RE: paintless dent removal?
Send me a pic of the dent, straight shot, and one from the side with a light reflection right on the dent if you can. I'll let you know what I think. Paintless dent repair = the ****! :-D
Old Apr 8, 2008 | 01:54 PM
lrgnation's Avatar
lrgnation
PDR is so worth it IMO. I have had 5 taken out but they were all real small and I had no idea two of them were there in the first place. I park 10 miles away from anything and still end up **** like this. Get a guy with atleast 10-15years experience and you will never know where it was. However some of the crappy pdr guys you will notice where it was before still.
Old Apr 8, 2008 | 03:18 PM
grampa_stang's Avatar
grampa_stang
I had it done...works great. You should watch how they do it. Even if it's a small
dent...the metal is still streched...so the trick is to shrink the metal without causing
the paint to flake/crack.
Old Apr 8, 2008 | 03:29 PM
Johnboy7701's Avatar
Johnboy7701
I've had it done before and its definately worth a shot... see what they can do for ya
Old Apr 8, 2008 | 04:16 PM
Tri C's Avatar
Tri C
Most any dent can be successfully removed by PDR if the paint isn't broken.The methodis so vastly superior to conventional body repair that it should always be one's first choice.
Old Apr 8, 2008 | 06:44 PM
harryalb2's Avatar
harryalb2
I have one on speed-dial. On the back panel, he just drilled a hole inside the door area behind the weather stripping to reach the ding, fixed the ding, then plugged the hole with a rubber stopper. Does amazing work without the expense of painting etc.
Old Apr 8, 2008 | 07:49 PM
americaniron's Avatar
americaniron
I had three small dents in a row fixed that way, and you couldn't even tell they were ever there.
Old Apr 8, 2008 | 07:54 PM
pnandy's Avatar
pnandy
ok I want to get this done to but i have a scratch on the inside of the dent i was thinking of using a paint pen and doing all the stuff required with that and then have the paintless dent removal guys do there thing anyone see any problems with this?
shockme76's Avatar
shockme76
I have a dent i haven't fixed yet because the quote i got was over $800. It's actually two dents on the right rear quater panel right before the wheel well. One of them is on the crease of the panel and i was told because of that i can't get the PDR. Is this true? They said they would have to remove my window and louver, remove the panel, get the dents out and then repaint. This was from the dealer.
