how do i take off mirrors?
The inside mirror covers, that hold the controls, pull right off with no fuss. Then disconnect the harness and unscrew the mirror. I'll find a link with the instructions...
http://www.swaaggs.com/documents/door_trim.pdf
That cover (number 1) just pulls right off, don't move back and forth, just pull straight out.
By the way, here's a link with a TON of walkthroughs...
https://mustangforums.com/m_1019059/tm.htm
pull the sail panel covers from the inside straight off. 3 10mm nuts I believe, disconnect the connector and pull the mirror straight out. Pretty damn simple, do not overtighten putting them back in otherwise you will see where the studs are fused to the plastic from the outside.
