Traction
Old Apr 8, 2008 | 08:19 PM
addison85's Avatar
addison85
Default Traction
After I got a CAI and Bamachips' 93 race tune, I tend to lose traction and have to be quite careful when accelerating to avoid chirping. You guys think getting 3.73 gears will make this even worse? Would you recommend performance tires before the gear upgrade??
Old Apr 8, 2008 | 08:24 PM
Joolander's Avatar
Joolander
Lord High Protector
Default RE: Traction
what tires do you have now? I'm running BFG's and have no problems with the 93 Race
Old Apr 8, 2008 | 08:32 PM
addison85's Avatar
addison85
stock BFG T/A G-Force KDWS. From a dead stop, I have to be cautious with the throttle or it will chirp.
Old Apr 8, 2008 | 08:38 PM
Joolander's Avatar
Joolander
Lord High Protector
as long as you don't floor it you should be fine
when you drive areal car like a mustang, its all about throttle modulation
Old Apr 8, 2008 | 08:39 PM
whtcanbrwnd04u's Avatar
whtcanbrwnd04u
ORIGINAL: addison85
I don't think you need performance tires b/c your chirping.
Old Apr 8, 2008 | 09:16 PM
Nuke's Avatar
Nuke
I went to 275/40/18 Eagle F1 all seasons from the stock 235/50/18 KDWS andmy hook-up is much better. But you need to lighten that foot... The KDWS is not a BAD tire and easily controllable.
Old Apr 8, 2008 | 09:26 PM
howarmat's Avatar
howarmat
s197 Junkie
you all must be stomping on the gas pedal.....i do have full suspension but i still never have any problem with accidental chirps and my car isnt even close to stock performance wise and 4.10s
Old Apr 8, 2008 | 09:29 PM
Aziraphale's Avatar
Aziraphale
ORIGINAL: addison85
Since no one else has answered this, yes, getting 3.73 gears will make it worse. Gears multiple your torque to the rear wheels effectively adding torque to your car (won't show on a dyno but WILL make it quicker). Anytime you add more torque, the problem will get worse.
Old Apr 8, 2008 | 09:41 PM
chain1's Avatar
chain1
Unless you have absolutely no ability to modulate the throttle, you should have no problem with unitentionally chirping the tires. It's not like these cars have the greatest throttle response anyway.
Old Apr 9, 2008 | 12:00 AM
Bluestar's Avatar
Bluestar
It's just a matter of getting used to the new throttle response, just keep it in mind when the ground is wet. Moreso if you upgrade to 3.73 or 4.10's
