Prochamber Exhaust Leak
The OEM h pipe has those little lock tabs on the back of the pipe where it connects to the overaxle pipes. The prochamber does not have that locking tab and I have a leak at the connection to the overaxle, I re-tightened both clamps with no luck. What can I do to get rid of this leak? Its so bad that you hear it rattle out of the back of the mufflers too[:@]
try putting another clamp on it http://www.jegs.com/webapp/wcs/store...11527_-1_10245
will do, thanks Joe. Can I pick a clamp up from autozone? I need to get it done this weekend if I can. Also I was told there is some kind of tape or something that can be wrapped around the exhaust and then put the clamps over that to prevent leaks...any idea what that is?
You sure those retainer clips on the stock clamp aren't vibrating against the pipe? Maybe just need to bend them away from the pipe or either secure them down with a clamp.
ORIGINAL: thewarmachine
Also check the other locations as well, might not be the clamp. Mine was slightly rubbing on one of the bolts on the tranny support. Sounded like something completely different than i was expecting.
