Thinking about these tires...
Old Apr 15, 2008 | 08:58 AM
ryanralston07's Avatar
ryanralston07
Default Thinking about these tires...
I'm going to a staggered setup and having 18x10s in the rear. I am set on 285's and can't decide between 285/60's or 285/40's...I think the 60's would look AMAZING in the rear and I wouldn't even have to lower the car to help with the 4x4 look[8D]Think the 285/60 would fit? Gah it'd look sooo good and hook like crazy(tire is BFGoodrich T/A KDW NT)
Old Apr 15, 2008 | 09:34 AM
Margarita Girl's Avatar
Margarita Girl
Is the tide gonna reach my chair?
Default RE: Thinking about these tires...
Hi, the 285/60 will definately fill the wheel well. You'd be adding 4 inches to the stock height. [8D]
Here's a handy tire size calulator:
http://www.1010tires.com/TireSizeCal...mp;vehicle=yes
Old Apr 15, 2008 | 09:38 AM
ryanralston07
Kind of worried about it though because I don't want to jack the rear up too high and lose performance...Think the tire will help at the track? Since i'm going to a bigger tire I could put in 4.10s and get crazy performance
Old Apr 15, 2008 | 09:45 AM
MTAS's Avatar
MTAS
ORIGINAL: ryanralston07
A 285/60/18 tire is over 31" tall! That will absolutely kill your gear ratio, unless you're going with 4.56's - for real. I have 295/45/18's on an 18x10 in the back, and 4.10 gears. Because of the additional tire height over stock, those 4.10's are now basically 3.90's. Something to thinnk about...
Old Apr 15, 2008 | 09:47 AM
GT Bob's Avatar
GT Bob
I was tihnking about going 275/60/17's myself... until I realized that with a 3.55 gear, my effective ratio would end up somewhere around a 2.90-ish. To end up getting near a 4.10 with a 29" tall tire, you would need somewhere around a 4.56..
Old Apr 15, 2008 | 09:51 AM
ryanralston07
ORIGINAL: MTAS
31.5" tall to be exactI'm looking at either 4.10s or 4.56s...ha my gas mileage is gonna suck but performance is gonna rock
Old Apr 15, 2008 | 09:57 AM
AmericanICON's Avatar
AmericanICON
ORIGINAL: MTAS
285/60 would be way tootall and 285/40doesn't fill the wheel well up enough, unless you lowerthecar. If you wantthe "big meats"on back, I'd alsosuggest 295/45/18. You end up with a 28.2" height- which is about an inch taller than stock (if you had 17s).
I haveNitto 555s 295/45/18 on an 18x10" rim on the rear only (need to update my sig pic) and it looksmean!!If you do gears, definitely go 4.10, because I have 3.73s, and with these new tires,I'm back to stock at 3.31:1.
Old Apr 15, 2008 | 10:18 AM
DarkFireGT's Avatar
DarkFireGT
I also have 295/45/18 on a 10" wheel and I think it's the perfect tire size. It's not so large that it really negatively affects performance, but it definitely looks meaty.
Old Apr 15, 2008 | 11:11 AM
FlaPony's Avatar
FlaPony
I noticed a slight performance drop when I switched to 295x45x18's.
Old Apr 15, 2008 | 11:18 AM
Boozshey's Avatar
Boozshey
All I can say is please don't put 60's on there...
You might as well raise the car and throw on 24's if you do that...
