ABS/ Traction control problem
Old Apr 16, 2008 | 10:37 PM
Maverick9110E's Avatar
Maverick9110E
Default ABS/ Traction control problem
so i had the traction control off, spun the tire's had some wheel hop. Now the damn ABS doesn't work, the ABS light is on, and the Trac control is stuck off and the Trac. control light is stuck on on the dash. Car drives fine brakes work, but the ABS doesn't. any idea? i'm guessing either a sensor is messed up or fell out/off, a fuse blew, or the ABS got overheated and it will have cooled off by morning? i turned the car off and turned it back on and still had the same problem.... HELP!! lol
Old Apr 16, 2008 | 11:26 PM
hammeron's Avatar
hammeron
Default RE: ABS/ Traction control problem
if you have a tuner, check for
trouble codes, then let us know
what it is
Old Apr 17, 2008 | 05:24 AM
Maverick9110E
don't have a tuner
Old Apr 17, 2008 | 06:44 AM
Maverick9110E
well i got under the car before i left for work this morning, ensured all the plugs were in and snug and started the car, same problem, but then within 5 minutes the lights went out and everything worked again, so either the dang ABS was overheated or one of the sensors did come loose and fixed itself once i snugged everything up.
Sep 8, 2015 11:50 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
M3hunter
Sep 5, 2015 03:42 PM
iculookin
Sep 2, 2015 12:34 PM
