Doing a long burnout
Old Apr 19, 2008 | 12:56 AM
Mike521's Avatar
Mike521
Default Doing a long burnout
Mine are usually 15 - 20 feet, lasting about 10 seconds (I'm just guesstimating)
anyone got some tips on making it scream and smoke and leave some serious tracks?
Old Apr 19, 2008 | 01:14 AM
StickShifty's Avatar
StickShifty
Default RE: Doing a long burnout
2nd gear and more HP???
Old Apr 19, 2008 | 01:16 AM
Mike521's Avatar
Mike521
I've never shifted to 2nd while doing a burnout, you do? won't the tires get traction while you shift and stop spinning?
Old Apr 19, 2008 | 01:19 AM
SeanoStang's Avatar
SeanoStang
maybe he means start in second
Old Apr 19, 2008 | 01:22 AM
StickShifty
if you spin 1st up nice for a bit and hold it, get off the brake and shift into second really quick. it will keep spinning and spinning and spinning.
but why, your just beating the car, and burning the tires. not worth it at all.
Old Apr 19, 2008 | 01:47 AM
landon.moss's Avatar
landon.moss
who cares...what's really cool is just roastin em while takin off and gettin those tire chirps with every shift as you storm off....plus at 100+ per tire, trans wear, etc...meh
Old Apr 19, 2008 | 01:58 AM
TOMBSTANG's Avatar
TOMBSTANG
get more power and slam that bad boy into 2nd gear and roast em like 50 feet.
Old Apr 19, 2008 | 12:31 PM
captainxanax's Avatar
captainxanax
Living at 7000', a long burnout is very hard n/a.
Old Apr 19, 2008 | 12:39 PM
marcuskeeler's Avatar
marcuskeeler
If you want a long burnout, then you got to hold it on the brake. You could manage it in 2nd but 1st is easier on everything.
Pretty much, once you get the wheels spinning, you can hold it like that as long as you want.
Just don't do the retard-thing of planting the throttle and letting the rev limiter do the work. People will just either cringe or laugh at you....or both. Get the wheels & motor spinning at a comfortable RPM where it's producing power enough for the job but no more, it's really not needed. Kinda hard to explain, have a look at mine here.
http://www.youtube.com/watch?v=_KFK_dID-Fk
Old Apr 19, 2008 | 01:58 PM
Stkjock's Avatar
Stkjock
Retired Mod
nice end Marcus....
get a set of line locks and you can really light them up
4.10 gears... and 2nd gear clutch drop!!!
