WTF...SCT2...help needed
Old Apr 28, 2008 | 07:11 PM
matt07GT's Avatar
matt07GT
Default WTF...SCT2...help needed
OK......so I put my new NT4's are nittos on today....and when I was adjusting my rev per mile a error message on the dash apperared saying check fuel level....than check charging system...than the whole thing went blank.....and the dash, port that i tuner is plugged into do not work......The weird thing is...is that the headlights work, interior lights work....but the car will not start either.
SO all in all
I got a check fuel level
Check charging system
Than everything went dead....and the tuner turned off
WHAT DO I DO NOW????????
Old Apr 28, 2008 | 07:14 PM
Ortoch's Avatar
Ortoch
Default RE: WTF...SCT2...help needed
try disconnecting the battery from the red connector for 30 minutes to let the system reboot
Old Apr 28, 2008 | 07:25 PM
matt07GT's Avatar
matt07GT
I'll give that a shot.........
Old Apr 28, 2008 | 07:33 PM
mlcrycc's Avatar
mlcrycc
I'm guessing blown fuse. Going by old memory, I believe it's fuse number 8?? The dash messages are normal for when you are changing the tune. They show every time.....Sounds like you got part way through, and blew the fuse.....
howarmat's Avatar
howarmat
s197 Junkie
check your fuses. The errors messages are normal though.
Old Apr 28, 2008 | 07:36 PM
grampa_stang's Avatar
grampa_stang
ORIGINAL: mlcrycc
Exactly right. Fuse #8 located behind the passenger kick panel. I'd bet $$$$ on it.
Old Apr 28, 2008 | 07:40 PM
matt07GT's Avatar
matt07GT
I hope you are right.......I am going to go check
Old Apr 28, 2008 | 07:42 PM
mlcrycc's Avatar
mlcrycc
ORIGINAL: grampa_stang
ORIGINAL: mlcrycc
...LOL....Two Grandfathers = 1 right answer.....[8D][8D]
Old Apr 28, 2008 | 08:04 PM
matt07GT's Avatar
matt07GT
Well.....the fuse was blown....my dad is on his way over to my place with his fuse kit..........that i bought him . SO.....when I put the fuse in will I have to reload the tune since it got cut off half way?
Old Apr 28, 2008 | 08:26 PM
Gene K's Avatar
Gene K
ORIGINAL: matt07GT
Yes. If you saved the changes just load the "Saved" file.
