D-Spec, Pro-Kit, Adjustable PHB
Old May 11, 2008 | 09:35 PM
zascott's Avatar
zascott
Default D-Spec, Pro-Kit, Adjustable PHB
How hard is it to install all these parts. I have all the tools and want to do it myself, but don't want to mess the car up.
Old May 12, 2008 | 06:54 AM
Argonaut's Avatar
Argonaut
Default RE: D-Spec, Pro-Kit, Adjustable PHB
Its not a difficult DIY job if you have the right tools. Although not required, having an impact wrench makes it a lot easier. A spring compressor, torque wrench, floor jack and jack stands are mandatory. Read the TacoBill "how-to's" - he has one for springs and dampers and another for the PHB. The PHB install is a no brainer, don't even need a guide except for the torque specs and how to do the adjustment. The rear springs and dampers are straight forward. The Fronts a little more difficult. It took me several hrs, over two days because I didn't have all the right tools and had to make a trip to Sears.You should check the pinion angle afterwards, it will probably be fine but its worth a check.
Also, if you are not aware: you should get the car aligned afterwards. You may need camber bolts or other type of camber adjustment if drop causes too much negative camber (according to Ford spec).Personally I like a lot of camber, the front end sticks better and I'll trade that for the slight increase in tire wear. The drop will cause the toe to change, so you need the alignment regardlessof camber changes.
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
