Struts & Shocks Going?
Old May 12, 2008 | 04:17 PM
05MustangSally's Avatar
05MustangSally
Default Struts & Shocks Going?
I wanted to know what the average life for the stock struts and/or shocks are on our Mustangs? I thought it was about 75K but I'm not sure. The reason I'm asking is because I think mine are ready to be replaced possibly. I haven't physically looked today but the ride makes me think so. Going over bumps and turns, etc. Does anyone know the usual mileage that these need to be changed? And any aftermarket recommendations?
Thanks ahead of time
Old May 12, 2008 | 05:20 PM
05MustangSally
Default RE: Struts & Shocks Going?
Anyone?
Old May 12, 2008 | 06:00 PM
fosman77's Avatar
fosman77
Is the car bouncing up and down? One way to test is to go one of the four corners of the car, Then push down pretty hard and see how many times the car goes up and down. It sould should pretty much stop after coming up, I believe if it bounces 3 or more times, the shock or strut is bad
Old May 12, 2008 | 07:21 PM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Get the Tokico D-specs or Koni's and any aftermarket spring you like for the drop and all problems are solved. Test the shocks like the above said and if they rebound more than once I would replace. I am not a mechanic but shocks/struts on other cars I have had when they rebound when compressed more than once should be replaced soon (for obvious reasons... safety, better handling, less wear on other components). I thought you already bought some new shocks and struts and springs? anyway let us know what happens.... J
Old May 13, 2008 | 03:59 AM
Orion_240's Avatar
Orion_240
pushing down won't show much. Your stock springs are so firm you'd have to be the Hulk to press down enough. It all depends on the ride, how the car handles dips and turns.
Check the Related Threads section below:
V
V
V
Old May 13, 2008 | 04:08 AM
MustangFan45's Avatar
MustangFan45
Dang, glad I read this forum. I didn't know that.
[IMG]local://upfiles/90468/201A52F7CE6B4BA08C31CEC323EC12E9.jpg[/IMG]
Old May 13, 2008 | 08:38 AM
timothyrw's Avatar
timothyrw
also check to see if your shocks/struts are leaking. that's a for sure sign then need to be replaced.
Old May 13, 2008 | 09:28 AM
MikeD916's Avatar
MikeD916
The other day I noticed my car was leaning to one side. The front drivers side is about 1/8 inch lower than the passenger but the rear is much worse. The rear drivers side is about 1/2 to 2/3 inch lower than the passenger side. I didnt notice any leak in the shocks. I've checked on multiple street surfaces and the results are pretty much the same. Does this signify shocks going bad?
Old May 13, 2008 | 06:16 PM
05MustangSally
Hi J! I did replace the springs a couple months ago with Vogtlands. Only a 1" drop though. I didn't change the shocks or struts or lower control arms. Just got the alignment. I'll try that and also check for leaks as others have mentioned. Thanks
ORIGINAL: mygt500
baddog671
Jul 26, 2016 01:20 PM
b8checker
Oct 8, 2015 12:55 PM
UrS4
Oct 3, 2015 06:23 AM
b8checker
Sep 30, 2015 07:11 AM
67STANGX2
Sep 24, 2015 12:29 PM
