Finished gauges!
Old May 13, 2008 | 02:45 PM
sevenleaf's Avatar
sevenleaf
Default Finished gauges!
Just finished installing my cobalt fuel pressure gauge works great.
I have a aeroforce gauge in the center dash, autometer boost/vac gauge in far left vent and an SOS gauge pod with Innovate wideband and a Cobalt Fuel pressure gauge.
Old May 13, 2008 | 02:51 PM
onederful100's Avatar
onederful100
Default RE: Finished gauges!
looks nice.
excellent job
hammeron's Avatar
hammeron
looks really nice leaf
where did you install the fuel pressure sender
Old May 13, 2008 | 03:34 PM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: hammeron
yes, very nice
Is that a mechanical or electric fuel pressure guage?
Old May 13, 2008 | 04:15 PM
sevenleaf's Avatar
sevenleaf
Thanks for the compliments, It's electrical installed using
"This convenient billet adapter mounts directly to the factory (or aftermarket equivalent) driver's side fuel rail, sandwiched between the rail and the OEM fuel pressure sensor. The fuel block seals with OEM-style O-rings, so no gaskets or sealants are required. Theinstallation is aquick and simple affair."
Old May 13, 2008 | 04:19 PM
hammeron's Avatar
hammeron
perfect choice!
you're one of the lucky ones who can
use that
Old May 15, 2008 | 12:24 PM
sevenleaf's Avatar
sevenleaf
Thanks for the compliments!
So I had a small leak at the fittings on the metco adapter couldn't find any information on how to seal the plugs but since Metco was closed I went ahead and used High temp Teflon Sealant. Let it cure overnight no more leaks(finally)!
I spoke to Metco this morning and they said you did need to use teflon sealant on the threads. So something finally went right for me but I wanted to mentionit since I could not find any information on this anywhere.
Old May 15, 2008 | 12:28 PM
2L8IWIN's Avatar
2L8IWIN
Looks great. I love the boost guage location.
Old May 15, 2008 | 03:16 PM
white07's Avatar
white07
Just 1 question. Why did you use 3 different kinds of gauges?
Old May 15, 2008 | 08:58 PM
rad_rob's Avatar
rad_rob
Not a huge fan of a pillar gauges but I know you need em to see whats going on. The auto meter ones arent too bad.
