Will this offset stick out??? 18x10 45mm
Old May 14, 2008 | 03:26 PM
Analyzer52's Avatar
Analyzer52
Default Will this offset stick out??? 18x10 45mm
I have been searching all day and can not find an answer about the wheels I'm interested in. I have an 05 covert GT. I want the Deep Dish Chrome Bullitt. I want 18x10 in the back with a 295-40-18 and 18X9 in the front with a 255-45-18. I don't want them to stick out pass the body of the car. American Muscle as the back offset listed as +45mm and +34mm for the front. Does this seem right? They have some pictures of peoples cars but it hard to tell from the pictures because they use the wrong angle. If anyone has this set up please post some picture from the back straight down the body of the car.
Are these sizes okay for a DD?
Link to wheel: http://www.americanmuscle.com/chrome...8x9-18x10.html
Edited to add front wheel size.
Old May 14, 2008 | 04:00 PM
torch red's Avatar
torch red
Default RE: Will this offset stick out??? 18x10 45mm
sizes are perfect ..i have 18x 10 rear w/ 285 and 18 x 9 front..w/ 255
Offsets are 38mm front 42 mm rear...with my wheels and they line up perfect..
if u go 45 MM all around u should be just fine...go 4 it..
[IMG]local://upfiles/19878/2E5C8E6E368049D0BE7E885C0DEEB717.jpg[/IMG]
Old May 14, 2008 | 04:09 PM
Norm Peterson's Avatar
Norm Peterson
Here are some dimensions that may help. They aren't exact, but should be pretty close. Best to compare vs the GT500 wheel for backspacing (they're 1/8" to maybe 3/16" deeper in back) and frontside spacing (about 3/8" further out). Or vs the GT 8.5" wheel (not quite half an inch more on the back and about 7/8" further out on the outside). Hope it helps.
GT 18" GT500 18" YOUR 10's
NominalWidth 8.50 9.5010.00in
Offset 504545mm
OverallWidth 9.7010.7011.00in
Backspacing 6.82 7.12 7.27in
FrontSideSpacing 2.88 3.58 3.73in
BTW, 10" is half an inch above spec for 255/45's and is visibly going to look slightly "stretched" to fit. Normally I'm not too concerned with being half an inch too wide with the wheel, but I'm a little bit uneasy with this particular combination at least without having the specific tire measurements from the exact make/model tires you intend to buy.
Edited so the table could be read.
Norm
Old May 14, 2008 | 04:22 PM
157dB's Avatar
157dB
Cut & Paste Expert
They will stick out 0.75" more than 18x8.5 45mm negative offset OEM rims.
1.5" wider equals 0.75" wider inside and 1.5" wider outside with the
same 45mm negative offset. The 34mm offset 18x10 fronts will be different
with more tire under the fender than the 45mm negative offset 18x10 rears.
You didnt state the front rim width so I am just guessing.
Old May 14, 2008 | 04:32 PM
Analyzer52's Avatar
Analyzer52
ORIGINAL: Norm Peterson
Norm
Some how I forgot to type in my orginal post, the front wheels will be 18X9. So that should be okay right?
Thanks for the chart that helped a lot.
Old May 14, 2008 | 06:12 PM
Norm Peterson
ORIGINAL: Analyzer52
You'll be fine (I'm assuming that the 9's are 45mm offset, for which the outside will be 1/2" inboard of where the GT500's outer face sits).
The chart was copied/pasted from a little spreadsheet I wrote. It's based on the FRPP catalog for Ford's OE alloy wheel flange widths (0.6") but I generally use 0.5" flange width for any unknown alloy wheel. A work in progress.
Norm
Old May 14, 2008 | 06:19 PM
DarkFireGT's Avatar
DarkFireGT
My FR500's are 18x10 +45MM rear and 18x9 +35MM front. They fit perfectly flush. You'll be fine with those. My tires in the rear are 295/45/18 and 255/45/18 front. The rear tires stick out just slightly. Here's some pictures. Hope this helps.
Old May 14, 2008 | 06:32 PM
Analyzer52's Avatar
Analyzer52
That's perfect thanks for the picture just what I'm looking for. Once I get the street scene rear bumper you won't even see the part sticking out.
What about this being for a daily driver any problems with that?
Do you have any issues with rubbing?
Old May 14, 2008 | 07:02 PM
Rubrignitz's Avatar
Rubrignitz
Yeah, nothing at all wrong with the 45 on a 10'. Just please, please don't go 24mm like some folks ona 9' rim. Reminds me of a the guys here in TX that have the rims sticking out 2' from the fenders. [&o]
Old May 14, 2008 | 07:07 PM
Rubrignitz's Avatar
Rubrignitz
Damn Darkfire, that is a perfect picture of the perfect offset for front/rear. Looks great!
