Just put on Pulley's
Just installed a set of Steeda UDP's and it was a pain in the A$$. For some reason we had some trouble getting the crank pulley fully seated but once we did everything was fine. The car pulls harder and runs a little smoother. I havent used my A/C yet so i dont know if they will effect it that bad.
Let us know how the A/C performs. Looks like you are in Florida, I am in Houston... Similar Summer heat. I want to do this upgradetoo, but I'm concerned about the A/C output on a 100* humid day.
ORIGINAL: saltydog1820
With UDPs, it will just be more on than off, thats all. You will not have it be on
100% of the time even with UDPs and Houston's 100% humidity.
ORIGINAL: 157db
The A/C is a demand on/off system withthe compressor clutchbeing off more than on.
I live near Daytona Beach in Florida and have ZERO problems with the UDPs. The A/C still works great as well as all other accessories. I gained at least 6 rwhp from the UDPs according to the dyno since it was hotter when I did the after dyno.
