Need help overdrive crank pulley automatic
Old May 24, 2008 | 07:05 PM
sevenleaf's Avatar
sevenleaf
Default Need help overdrive crank pulley automatic
I am trying to get my crank bolt off but the engine keeps turning.
I noticed in taco bills thread he stated
"Note: (per Steeda) On Automatic transmission cars, prevent the engine from turning by holding the torque converter. Access the torque converter by removing a plug towards the front Drivers side of the transmission. Hold the torque converter from turning with a 14mm wrench. "
Where is this location? Is it under the car? Help!
Thanks
Old May 24, 2008 | 07:21 PM
DarkFireGT's Avatar
DarkFireGT
Default RE: Need help overdrive crank pulley automatic
Apparently, he didn't update the version on here. The version on TMS shows the access hole.
Note:
It's pretty hard holding a wrench on the bolt while the crank is being torqued. It's possible, just takes patience. If the wrench slips off, rotate the crank bolt until you can get a wrench of the bolt again. This is a 2-man operation!
GimpyHSHS
19
Dec 19, 2023 01:12 PM
svfetter
Oct 5, 2015 11:39 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
