Service Engine Code Help
Old May 25, 2008 | 09:09 AM
ErcWrestlr's Avatar
ErcWrestlr
Default Service Engine Code Help
I got this code while driving normally this morning. Does anyone know if it was just a glitch or is there something I can do to fix this problem? This is what I was able to find out online. Any extra help is appreciated!
P0456 - EVAP Control System Leak Detected (Very Small Leak)
Description --The PCM monitors the complete EVAP control system for the presence of a very small fuel vapor leak.The system failure occurs when a fuel vapor leak from an opening as small as 0.508 mm (0.020 inch) is detected by the EVAP running loss monitor test.
Possible Causes --Very small holes or cuts in fuel vapor hoses/tubes. Loose fuel vapor hose/tube connections to EVAP system components. EVAP system component seals leaking (refer to Possible Causes under DTC P0442).
Old May 25, 2008 | 09:33 AM
HMUSN's Avatar
HMUSN
Default RE: Service Engine Code Help
tighten your gas cap..
seriously.
Old May 25, 2008 | 09:49 AM
ErcWrestlr's Avatar
ErcWrestlr
Hmmm. Okay. I'll give that a shot. That is a very easy fix if that does it. Thanks HMUSN
Old May 25, 2008 | 11:35 AM
HMUSN's Avatar
HMUSN
keep us updated.
Old May 25, 2008 | 12:57 PM
06GT4RAD's Avatar
06GT4RAD
ORIGINAL: HMUSN
seriously.
Yep that's probably it.
I had this a few weeks ago. Turns out when i was cleaning the car i hit the gasp cap and loosened it just enough to trigger it.
And yes i clean inside the gas door area.
Old May 25, 2008 | 06:27 PM
ErcWrestlr's Avatar
ErcWrestlr
I reset the light and I took the cap off and put it back on. Everything seemed fine with it. Took the car out for a good 45 minute drive and no more light came back on. Seems fixed for the time being.
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
mdj89
Sep 6, 2015 11:08 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
kevans79@yahoo.com
Aug 18, 2015 08:16 AM
