Traction?
Old May 25, 2008 | 11:28 AM
ryanvw's Avatar
ryanvw
Default Traction?
k guys i just got back from the track and ya traction is an issue! i did better 60ft's in my fwd gti ha! what you guys using to help? (dr's, slicks, traction bars?)
13.6@105 2.2 60ft
Old May 25, 2008 | 01:01 PM
MikesTorchedGT's Avatar
MikesTorchedGT
Default RE: Traction?
some Drag radials should do the trick, if you want you could get some LCAs for the wheel hop witch I'm sure your ettin *** well but with good set of DRs you shouldn't need them
Old May 25, 2008 | 01:44 PM
cobra443's Avatar
cobra443
+1^ Also if you are going to hit the 1320 often you might want to invest if some ET Streets. I would defiently reccoment some LCA's especially with upgraded tires to support harder launches.
Old May 25, 2008 | 02:06 PM
ThumperMX113's Avatar
ThumperMX113
Get drag radials, LCAs/Brackets and UCAs.
Old May 25, 2008 | 04:27 PM
cobra443's Avatar
cobra443
To the OP you only need the relocation brackets^ if your lowered.
Old May 25, 2008 | 06:04 PM
slvrstang2007's Avatar
slvrstang2007
Traction? Whats that?
ChampInSD
Oct 2, 2015 04:55 AM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
Sep 8, 2015 11:50 AM
iculookin
Sep 2, 2015 12:34 PM
ccwebb
Aug 11, 2015 06:47 PM
