2 easy questions????Dyno
Old Jun 3, 2008 | 07:19 PM
1morepart's Avatar
1morepart
Default 2 easy questions????Dyno
1. what gear "should" the dyno use to pull for hp an tq?
2. how often do you guys use sea foam or the equivalent? please advise
thanks
jason
Old Jun 3, 2008 | 07:32 PM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: 2 easy questions????Dyno
4th gear
every 6 months
Old Jun 3, 2008 | 07:44 PM
1morepart's Avatar
1morepart
thanks matt!!!!!
Old Jun 3, 2008 | 11:33 PM
1morepart's Avatar
1morepart
when did everyone start using sea foam? matt recommended after 20k miles
Old Jun 4, 2008 | 05:34 AM
MustangFan45's Avatar
MustangFan45
sea foam???
Old Jun 4, 2008 | 01:30 PM
Sancho805's Avatar
Sancho805
that soapy looking stuff that forms right after a wave breaks. they collect it, put it into cans and then sell it....[8D]
Old Jun 4, 2008 | 01:48 PM
1morepart's Avatar
1morepart
no, i thought it was fresh water riptides that produced a sea like foam
Old Jun 4, 2008 | 03:15 PM
SuperSonic05's Avatar
SuperSonic05
what is this &quot\\;sea foam&quot\\; and want does it do?
Old Jun 4, 2008 | 03:45 PM
onederful100's Avatar
onederful100
&lt\\;P&gt\\;&amp\\;lt\\;\\\\\\;P&amp\\;gt\\;\\\\\ \;&amp\\;lt\\;\\\\\\;A href=&quot\\;\\\\\\;http://www.seafoamsales.com/&quot\\;...\;gt\\;\\\\\\; will clean out your intake, PCV valve, or fuel line.&amp\\;lt\\;\\\\\\;/P&amp\\;gt\\;\\\\\\;&lt\\;BR&gt\\;&amp\\;lt\\;\\\\ \\;P&amp\\;gt\\;\\\\\\;kinda like carb cleaner, or injector cleaner&amp\\;lt\\;\\\\\\;/P&amp\\;gt\\;\\\\\\;&lt\\;BR&gt\\;&amp\\;lt\\;\\\\ \\;P&amp\\;gt\\;\\\\\\;&amp\\;amp\\;\\\\\\;nbsp\\\ \\\;&amp\\;lt\\;\\\\\\;/P&amp\\;gt\\;\\\\\\; &lt\\;/P&gt\\;
&lt\\;P&gt\\;&amp\\;nbsp\\;&lt\\;/P&gt\\;
&lt\\;P&gt\\;idk what all that messed up wording is, just came out like that i didnt even type all that stuff, but you can read between the lines&lt\\;IMG src=&quot\\;https://mustangforums.com/image/s1.g...&lt\\;/P&gt\\;
Old Jun 4, 2008 | 07:30 PM
1morepart's Avatar
1morepart
it just cleans the fuel system, crank case, heads, valvles(you know the unimportant things)
