Time for a new clutch?
Old Jun 7, 2008 | 10:08 AM
ryanralston07's Avatar
ryanralston07
Default Time for a new clutch?
Lately I've seen that when I really get on it and shift hard the rpms hang out a little too high and the clutch doesn't seem to disengage although my foot is COMPLETELY removed from it and the pedal is all the way out? It's just not catching the same as it used to...worried it could be my transmission...but it does it in all gears...so what clutch would you pick and why? My goals are to have a car with 550 rwhp or a little more...not looking to top over 625rwhp for awhile. This is just part of the build I guess[&:]
OH and the car is my DD and will be at the track probably once or twice a month...
Old Jun 7, 2008 | 10:20 AM
buster's Avatar
buster
Default RE: Time for a new clutch?
If you want to check if your clutch is slipping do a brake torque. If you have alot of power, you might be overpowering your clutch. The car willeventually tell you the clutch has given out. Might just need adjusting.....I don't know if they can be adjusted however. Good luck
Old Jun 7, 2008 | 10:34 AM
Riptide's Avatar
Riptide
Someone once told me another way to check if your clutch is going is to put it in third and dump it. If it stalls it's OK.
Old Jun 7, 2008 | 11:26 AM
rogan01's Avatar
rogan01
Would you take it to the dealer?
Old Jun 7, 2008 | 12:52 PM
Simon1's Avatar
Simon1
I knew mine was done when I did some WOT pulls in 4th and the power just burned right through the clutch and spun the rpms up to 6000+.
I replaced it with an RPS twin friction rated at 600 TQ, their cynrgy flywheel and pressure plate. No problems. It never chattered, vibrated or slipped. The pedal is heavier but I expected that. I'm very happy with it.
There are some really good units out there. Some guys are looking at the Mcloud RST, twin disc that holds 800 TQ I beleive with the same pedal pressure as stock.
Old Jun 7, 2008 | 01:02 PM
ryanralston07
I was thinking like Spec 3 clutch maybe? Would I need to replace the flywheel or could I use the stock flywheel?
Old Jun 7, 2008 | 01:03 PM
ryanralston07
What's a brake torque?
Old Jun 7, 2008 | 01:57 PM
rford426's Avatar
rford426
ive heard specs are good
Old Jun 7, 2008 | 08:39 PM
ryanralston07
Anybody else?
Old Jun 7, 2008 | 09:08 PM
Brian76's Avatar
Brian76
Holding the Brake down while doing a Burnout = Brake Torque
