Hurst vs. MGW
Old Jun 17, 2008 | 11:15 PM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Default RE: Hurst vs. MGW
The MGW is great with a very nice short throw but with stock like feel but never miss second or third on hard high RPM shifting (motor mounts and/ or torque limiters will help further). Like a very sharp knife thru butter! Very great shifter! cant say enough and I am sure others will chime in with the same!
ORIGINAL: GuitarGuyBMG
I have the Hurst shifter as of now. I installed it about a year ago. At first I liked the notchy feel of it, but now it's grown tiresome. Does the MGW have a smoother feel to it?
Old Jun 21, 2008 | 08:53 PM
Darkness7's Avatar
Darkness7
I've noticed with my Hurst that sometimes I miss 2nd ....yes I said 2nd, and that to me is just crazy... I'm considering going another route, but I like the look of the Hurst... not to mention I've already badged the side "Hurst Equipped" (but we can replace that of course) Does the MGW utilized the stock **** and handle? I would like something similiar to the Hurst look...
Old Jun 22, 2008 | 09:07 AM
mortman's Avatar
mortman
You can order the shifter to handel the stock **** as i did or pick up a retro ball at your local speed shop. I had th eolder hurst, swapped it out for the MGW, much better. Installed the Hurst in a buddys car yesterday, changed the tranny fluid and replaced it with Royal Purple "Syncromax" and the notchyness is gone and no more missing gears. I have never used syinthetcs in any car before "I am now a beleaver".
Old Jun 22, 2008 | 10:32 AM
pascal's Avatar
pascal
S197 Section Modder-ator
ORIGINAL: Darkness7
Missing secong gear?[&:]
Sorry budd, it ain't the shifter.
Unless yours is defective...
Mine has been flawless.
Old Jun 22, 2008 | 10:52 AM
CFLstangGT's Avatar
CFLstangGT
The Hurst has been good to me, not a chance on missing second, third is waaaaaaaaaaaaay better. Notchy yes, but i'm happy.
Darkness7's Avatar
Darkness7
Trust me, its the shifter and its been installed correctly. More than a few buddies have driven it and said the same thing about second. I'm gonna try Royal Purple synchromax fluid and see if that solves it.
Old Jun 22, 2008 | 11:02 AM
mygt500's Avatar
mygt500
Darkness it sounds like it might be time for motor mounts or torque limiters which will help solve the missing second if this is happening at high RPMs. The motor is flexing and causing the second gear miss IMO....not the shifter. If it is not at high rpms than could be something else....maybe syncro's?
Old Jun 22, 2008 | 11:04 AM
Riptide's Avatar
Riptide
Why is it my car which is practically stock except for the CAI/Tune doesn't have this issue? I never miss 2nd. Even when going WOT from a dig.
Old Jun 22, 2008 | 11:10 AM
Darkness7's Avatar
Darkness7
Hmm... I will have JPC in Glen Burnie check it out for me when I got get it dyno tuned with the juice... I doubt that it would be syncro's the car doesn't have very many miles on it at all and its a weekend driver... I haven't thorn the gears up that bad just yet.
Old Jun 22, 2008 | 11:14 AM
mygt500's Avatar
mygt500
Could still happen under load and the CHE K member brace and torque limiters is cheap assurance from the motor flexing and thats what it sounds like. Easier install than motor mounts and should help eliminate or reduce the flex and hopefully the missed second shifts.
carid
Jul 8, 2016 09:55 AM
firehorse02
Nov 16, 2015 11:28 AM
JT76
Sep 20, 2015 11:32 AM
Webster454
Sep 7, 2015 04:59 AM
