hids help
ok so i intalled a hid kit today and they only work when i have the hi beams on, which wouldnt bother me as long as they worked but when the hi beams are on u cant have foglights. the kit was a single beam so the only way for them to work so far is with hi beams on. has anybody had this problem and found a way to fix it? i like the brightness of the hids but whats the point of having fogs if i cant use them? and search is still down otherwise i would have looked.
Hook them to the low beam wires with a lighting relay.
You must use a relay so the SJB wont freak out and start
flashing your HIDs.
http://iihs.net/fsm/?dir=40&viewfile...0Autolamps.pdf
flashing your HIDs.
ORIGINAL: 157db
flashing your HIDs.
flashing your HIDs.
Diode Dynamics
28
May 26, 2022 12:02 PM
inyadreems
Aug 21, 2015 09:10 AM
stangmods.com
121
Mar 9, 2009 01:18 PM
