Time to change the Plugs
Old Jun 23, 2008 | 10:18 PM
302me's Avatar
302me
Default Time to change the Plugs
I'm going to "attempt" to change the plugs in the 06 tomorrow. I've never done plugs on a car before and a little advice and words of wisdom would be appreciated. How much of a pain in the bawlz is the whole ordeal, or is it pretty much a simple in and out job? I got raped by the dealer last time I needed anything done, so I'm trying to inhance my base knowledge in the DIY area. Thanks for the help.
Old Jun 23, 2008 | 10:23 PM
Lifter583's Avatar
Lifter583
Default RE: Time to change the Plugs
You might look over some of the other threads on GT plug changes. THEY ARE NOT A NORMAL PROCEDURE! or easy, How many miles does your car have?
check this :https://mustangforums.com/m_4612371/...tm.htm#4612371
Old Jun 23, 2008 | 11:12 PM
AllGT's Avatar
AllGT
Yes my advice would be to take your time. Make sure the engine is warm, use penetrating oil (i used deep creep), start with the torque wrech set low.. like 20 lb-ft. One of them is destine to be really hard to get out but twist it a little at a time back and forth being very patient. My stang had 18,000 miles when I did it. Used the champion's and the cars runs great.
Old Jun 23, 2008 | 11:16 PM
mestit3's Avatar
mestit3
i would make sure to use a torque wrench
Old Jun 24, 2008 | 01:26 AM
sailing220's Avatar
sailing220
If a 17 year old kid in his garage can do it, so can you. It really isn't as hard as people make it seem. Unless you're a dumbas$ who is going to crank them out in 3 seconds, you'll probably be fine. Follow the TSB (don't have a link, sorry, maybe look in some other threads on the subject) closely.
Old Jun 24, 2008 | 11:07 AM
302me's Avatar
302me
I don't think I'm going to have a bawlz of a time, just wanted to get a little advice before hand. I have 68,000 on her now. I'll let you guys know if I have any issues. Thanks.
Old Jun 24, 2008 | 11:47 AM
Mikes_BLK_GT's Avatar
Mikes_BLK_GT
ORIGINAL: AllGT
One of the first things the Ford TSB states is to do this job at room temp. This is because you have aluminum heads and threads on the plugs stand a good chance of damaging the threads on that aluminum head when the engine is warm or hot due to its softening up. I work with aluminum parts in high heat applications(typically 400 degrees Celcius) and can vouch for the above information.
Old Jun 24, 2008 | 12:09 PM
schapman's Avatar
schapman
Room tempature? how do I get my car in the house? lol
Old Jun 24, 2008 | 12:22 PM
richmod's Avatar
richmod
I couldn't break them loose at room temp at 25 on the torque wrench. I HAD to warm the engine. just run the emgine for about 5 minutes till it's warm to touch, but not hot. Break em loose, add the carb cleaner, wait like an hour, then slowly remove them.
Old Jun 24, 2008 | 12:35 PM
Mikes_BLK_GT
ORIGINAL: schapman
LOL I figured someone would come up with a crack like that. Believe it or not that is exactly how its worded.
