1/4 Mile with Tokico D spec
Old Jun 26, 2008 | 10:02 PM
MUSTANGEXPERT's Avatar
MUSTANGEXPERT
Default 1/4 Mile with Tokico D spec
I am going to the track friday and i would like to know everyone who has the ajustable shocks and struts by tokico what you setting your stiffness too...Need advice.. please help
Old Jun 26, 2008 | 10:21 PM
owero01's Avatar
owero01
Default RE: 1/4 Mile with Tokico D spec
Hard for the rear and soft for the front. Helps to transfer the weigt to the rear tires.
Old Jun 26, 2008 | 11:20 PM
FyouGitive's Avatar
FyouGitive
And it does make a difference.
Old Jun 27, 2008 | 07:41 AM
Argonaut's Avatar
Argonaut
Yep - I did a little test: 36psi in rear tires, D-Specs at 4 front and rear. Did a couple passes. Then I dropped the psi to ~25, Front struts at 6, Rear at 2. Took 2/10ths off my ETs.
Old Jun 27, 2008 | 08:36 AM
MUSTANGEXPERT
Thanks we will see what happens
Old Jun 27, 2008 | 12:26 PM
Kaldar142's Avatar
Kaldar142
when you say rear at 2, is that 2 turns fromm full stiff or 2 turns from full soft?
Old Jun 27, 2008 | 12:37 PM
drbobvs's Avatar
drbobvs
7 out front, 4 out rear.
Old Jun 27, 2008 | 12:44 PM
Z06 Killer's Avatar
Z06 Killer
ORIGINAL: Argonaut
Well that is not that great of a test..... You prolly got most of that .2 from dropping the rear preassure 11 p.s.i. You should have done a few runs with the lower preassure then a few with the D-spec adjustment and compared!
Old Jun 27, 2008 | 01:52 PM
Kaldar142's Avatar
Kaldar142
where should i have my rear adjustment set at then?
before i had it about 2.5 turns from full soft when i went to the strip and full soft front
Old Jun 27, 2008 | 03:08 PM
scramblr's Avatar
scramblr
Full soft in the front, 2.5 passenger side rear, 3 driver side rear. This allows my car to launch dead center. I do need to play with it sometime depending on track temp to ensure the car stays straight. That's what I love about the D-Specs.
