NEW CAMS?
Old Jun 28, 2008 | 04:35 AM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: NEW CAMS?
i wouldnt attempt it, and "alot of power" is not really true either, you need very good tuning and a very good setup with supporting mods to get good power
Old Jun 28, 2008 | 06:55 AM
Hootna's Avatar
Hootna
Heres an article about it step by step install with new springs.
http://www.musclemustangfastfords.co...ams/index.html
Unless you want to go with the No Springs Required cams that are being sold. I was going to go with the FRPP NSR cam but have now changed my mind and am installing a comp cams which needs replacement springs. I am dropping my car off at the shop today but it is not a cheap swap. I was quoted $700 for install then add in tuning etc. I wish I could do it myself but I am not that skilled.
Old Jun 28, 2008 | 08:03 AM
DarkFireGT's Avatar
DarkFireGT
If you get the Brenspeed or FRPP NSR cams, you shouldn't have to pay more than $300 or so for the installation. I would leave it to the pros. I was also led to believe you needed a few tools from Ford that end up costing about $300 if you do it yourself. You'll get the most power from a dyno tune, so after install, I would find a local dyno tuner. If you go with the Brenspeed cams, then an email tune would probably be sufficient (though I would still datalog and send the dyno and data back to Brenspeed to have the tune tweaked).
Old Jun 28, 2008 | 08:52 AM
rojizostang's Avatar
rojizostang
cheapest install price i could find for the nsr cams was $600. special tools are required. the frpp cams are probably $750 + 600 for install + 300 for a custom dyno tune (all local prices)
$1650 total
Old Jun 28, 2008 | 12:36 PM
DarkFireGT's Avatar
DarkFireGT
That's inflated as all heck. Brenspeed charges about $300. I wouldn't think Sutton would charge much different from that.
Old Jun 28, 2008 | 10:06 PM
GTX141's Avatar
GTX141
What possible "special tools" would be required for a cam swap other than possibly a gear puller?
Old Jun 28, 2008 | 10:45 PM
Legion5's Avatar
Legion5
ORIGINAL: GTX141
Words like gear puller and special tools made med decide to get my comp cams installed at a pro the second i started researching it. I've put on superchargers before I see no reason to ever leave a cam instal to anyone but a professional.
Besides this I know people that have damaged their engines over installing cams wrong. They didn't learn the first time and blew 2 engines.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
