ordered my gt500 spoiler
Old Jun 30, 2008 | 01:06 PM
GOTTORQ's Avatar
GOTTORQ
Default ordered my gt500 spoiler
ordered it from the spoiler store on ebay, i think it will bring my car all together i hate the stock spoiler, any tips on the install guys?
Old Jun 30, 2008 | 01:10 PM
ink003's Avatar
ink003
Default RE: ordered my gt500 spoiler
it's fairly straightforward - be certain to:
1. remove all the adhesive from the stock spoiler
2. plug the extra two holes, using silicone to ensure they don't leak
3. carefully line up the new gt500 spoiler before fully removing the tape lining
all said and done, it's pretty simple - good luck!
Old Jun 30, 2008 | 01:11 PM
GOTTORQ's Avatar
GOTTORQ
ink thanks for the tips, now how the hell do you get ur pic in your signature? its not letting me show mine
Old Jun 30, 2008 | 01:20 PM
ckone0814's Avatar
ckone0814
use lots of adhesive remover (I used Goo Gone) and keep adding more, use fishing line, while you're sawing with the line pull up and away friom the body, and above all, BE PATIENT. take your time to slowly cut your way through the tape. i did mine in the hot sun or use a hairdryer to soften the tape.
set new spoiler on car with adhesive backing still on. once you got it right where you want it, remove backing a little at a time while someone helps keep the spolier in place.
good luck.
Old Jun 30, 2008 | 01:37 PM
GOTTORQ's Avatar
GOTTORQ
thanks for the info
Old Jul 1, 2008 | 07:22 AM
white07's Avatar
white07
what are you planning on doing with the stock spoiler? PM me if you are looking to sell it.
Old Jul 1, 2008 | 08:27 AM
TPony's Avatar
TPony
Congrats...you should have no problems with the install. The most challenging part will be removing the old 3M tape.
Old Jul 1, 2008 | 11:23 AM
Ato's Avatar
Ato
ORIGINAL: ckone0814
good luck.
Definitely recommend Goo Gone. I was rubbing on a small section off the tape w/ soap and water for 20 minutes w/o much of a difference and got sick of it and said F**** this! Went to Home Depot, sprayed the both spot, let it sit for 5 minutes and had both sides done 10 minutes later w/o any harm to the paint. Just make sure you are getting the stuff that is orange and oily in a pump bottle b/c people often confuse it w/ Goof Off which is in an pressurized can and is likely to damage your paint.
Old Jul 1, 2008 | 11:42 AM
smokestang's Avatar
smokestang
Gottorq....how much did it cost?...did itcome already painted? thinking about getting one myself.
Old Jul 1, 2008 | 11:53 AM
sandy's Avatar
sandy
I didn't know thecar has a "stock" spoiler? What am I missing?
