problem after disconnect battery.
Old Jun 30, 2008 | 02:18 PM
capitalautomall's Avatar
capitalautomall
Default problem after disconnect battery.
yesterday i disconnect my battery and try to install HID FOG. after i finish.
i reconnect my battery and start the car. for some reason when i step on the gas my rpm rev high and stay there. i have JLT cia and evo tune. do i have to reload the tune after? people told me the comp will reset itself. so i dunno. anyone have the same problem before?
and also im looking for 4.10 gear. right now i have 3.55 .fred from
evo told me i can just change the gear ratio with the sct
tuner myself. dont need a new tune. is that ture?
Old Jun 30, 2008 | 03:07 PM
157dB's Avatar
157dB
Cut & Paste Expert
Default RE: problem after disconnect battery.
Tunes are stored in non volitile memory.
It wont disappear unless you change it.
Wouldnt that be a pisser if you had to
get your tune reloaded because of a
dead or disconnected battery.
The adaptive learning is not stored in non volitile memory.
Dis-connect the battery and the adaptive learnng parametersare gone.
How many miles are on her? The more miles, the more different
the adaptive learning parameters are from the default, battery
disconnected, parameters of a new engine.
Maybe you should try the adaptive learning procedure.
Have you re-calibrated the gas pedal?
Maybe try re-calibrating it.
Have you done the bend the springs gas pedal mod?
You can change the revs/mile in the SCTwithout modifying
the tune you are curently using.
Old Jun 30, 2008 | 04:49 PM
capitalautomall
i just loaded the 93 tune in there this afternoon. everything seem ok. but i do feel the a lil different when i step on the gas. the car feel like more aggressive
btw now she got 5k mile on her. but what you mean by Have you re-calibrated the gas pedal?
Old Jun 30, 2008 | 05:51 PM
Z06 Killer's Avatar
Z06 Killer
ORIGINAL: 157db
I too would like to know how to recalibrate the pedal
and I am real interested in the spring gas pedal mod!
Old Jun 30, 2008 | 07:08 PM
GidyupGo's Avatar
GidyupGo
The gas pedal mod is a long one and should be in the search funtion. The adaptive learning curve will adjust within 20 miles back to normal driving styles so enjoy it while it lasts.
Old Jul 1, 2008 | 08:38 AM
Leoleo's Avatar
Leoleo
YES, I have the XCAL3 and I know the XCAL2 can also do this. I think this settingis on most turners.
Old Jul 1, 2008 | 09:44 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: Z06 Killer
ORIGINAL: 157db
Turn on ignition without starting engine.
Wait for idiot lights to cycle and extinguish.
Slowly depress the gas pedal and slowly release
it a few times.
Turn off ignition.
Recalibration done.
Adaptive learning:
http://www.analogstereo.com/pdf/om/m...anual_2006.pdf
Page 204
Old Jul 1, 2008 | 10:45 AM
Z06 Killer's Avatar
Z06 Killer
ORIGINAL: GidyupGo
Have you ttried the search lately? It has been broke for quite some time now.
Old Jul 1, 2008 | 06:35 PM
Z06 Killer's Avatar
Z06 Killer
so no word on the spring mod?
Old Jul 1, 2008 | 08:04 PM
Stoenr's Avatar
Stoenr
I heard most tuners turn off adaptive learning in the the tune. Anyone else?
