Lower GT/CS
Old Jul 11, 2008 | 11:22 AM
2008gtcs's Avatar
2008gtcs
Default Lower GT/CS
I have seen different posts for reducing the ride height of our cars but since the CS is a little low in the front already, I'd like to just get the rear end down a bit. This car has a few tweaks but is it a cruiser for sure - no road/drag racing. I've also seen some recommendations for Roush rear springs only and I like the idea of re-using the shocks etc, since the car has less than 500 miles on it.
Are the springs I need part # 401295 ? Also any help with a "how to" thread on this would be appreciated.
[IMG]local://upfiles/94784/01347B0FBF954CC2B809297364AC1ECC.jpg[/IMG]
[IMG]local://upfiles/94784/A3767A026A4D4C6EBB5977627F9CED61.jpg[/IMG]
Old Jul 11, 2008 | 05:58 PM
EricM's Avatar
EricM
Default RE: Lower GT/CS
It's the stock suspension height in front, it's just the fascia that hangs a bit lower. There are a lot of people that run the Roush rear springs only, but the looks aren't for me.
Old Jul 11, 2008 | 06:07 PM
xtoolmaker's Avatar
xtoolmaker
Thats the right number for the Roush springs . I put them on my 2008 CS lowered about 1 inch made the back wheel well to tire the same as the front. TacoBill has a write up on the install.Takes about 1to 2 hours from jack up to jack down.
Old Jul 11, 2008 | 07:06 PM
2008gtcs's Avatar
2008gtcs
yes indeed. about 1" lower in the rear will equalize F-R attitude and that is a good look/ride for me too. Thanks for the "how to" heads up - I found it.
Old Jul 11, 2008 | 07:26 PM
BeachBlv's Avatar
BeachBlv
something i would like to see done is the sportline springs in the front and pro kit in the back, to give the car a muscle car stance.
Old Jul 12, 2008 | 12:18 PM
2007CalSpec's Avatar
2007CalSpec
I have a GT/CS also. Great choice in color by the way! Ihad the same thoughts in the past about what springs to get because of the lower CS front fascia so I did some research and found springs that has the lowest amount of drop in front which were the Tein H Tech springs. I have them on my car and I love them. The drop is only 0.9" in front and 1.7" in the rear. I don't have a problem going over speed bumps and the car rides almost as smooth and comfortable as stock. I've seen cars with just the rear loweredand the front/rear wheel gaps don't look right since the rear wheel gap will be smaller now compared to the unlowered front.
Here's my car on Tein H Tech springs.
Old Jul 12, 2008 | 01:33 PM
2008gtcs's Avatar
2008gtcs
Nice fastback. Overall yours does look lower than stock and I like the sleek look with no hood scoop and v6 spoiler(?) . I especially like the black on white combo and your red calipers look great.
maybe because of the heavier weight or distribution of the weight, but on the 'vert, the rear gap between the tire and fender well is exactly 1" higher than the front. Plus i think i can tackle the job on the rears but the front spring change out looks like I'd be getting in over my head.
Old Jul 12, 2008 | 01:39 PM
deekum1627's Avatar
deekum1627
i think you can do the front its not any harder then the back good luck man nice car
Old Jul 12, 2008 | 04:30 PM
Bullitt#3949's Avatar
Bullitt#3949
Sweet CS fastback
Old Dec 17, 2008 | 08:05 AM
jymontoya's Avatar
jymontoya
Gorgeous 2007CalSpec.
You've got a PM.
