Alarm question
Ok so I just had a “security event” and my alarm was going off. Went and turned off the alarm and did a quick look over the car and couldn’t find any scratches or dents. I have the passive anti theft system that came with the car. My question; is there a way to tell what or which sensor actually tripped the alarm soI know where to look? I did a quick scan of the owner’s manual but didn’t see anything. Can the stock alarm tell me this info or is it beyond the systems capabilities?? Also I had the windows down, does anyone have problems with the cabin motion sensors being tripped by things outside the car?
ORIGINAL: rehtorb
Anyway, was the car unattended? Maybe someone reached in the window.
ORIGINAL: wthalliii
[/quote]
Yeah i ment active and it was unattended outside my house. Its possible that someone did reach into my car but I dont keep anything in it. I was just wondering if the alarm system would give me more info about the event.
False alarms with the windows down and the active theft system armed
are common. Roll up the windows if you are going to activate the alarm.
Or expect false alarms to occure.
Even a wind gust is enough to set the system off if the windows are down. Personally, I'm glad it has that amount of sensitivity.
To my knowledge, the system doesn't have the ability to tell you what set it off.
Funny...that just happened at lunch today. Took the boy out for tacos on the patio and while admiring the Stang....the alarm went off. Noone was around and, yes, the windows were down.
What sensor is too sensitive??
It would be the motion sensor. It's senstive to pressure changes which occur as a result of movement. So much that when you've engaged the system and then open the trunk it disengages the motion sensor. The pressure change when you open or close the trunk lid will set the system off otherwise.
