Yes... Forget performance, Get black clear corners with stelth bulbs, The black\red front does not jive at all with the orange corners, I think it would make a huge difference...
New lower controls arms. Adjustable might be best if you want to lower the car later, especially if you end up with a one piece drive shaft.
As a second option, you can get fixed lower control arms now and just go for an adjustable upper control arm later if you choose to do a mod that changes the suspension geometry significantly. If you stay with the stock ride height, then you will be better off with fixed lower control arms.
