Quick Eibach prokit lowering spring question
Old Jul 21, 2008 | 12:38 PM
SlinkyBMX's Avatar
SlinkyBMX
Default Quick Eibach prokit lowering spring question
Might order this today but when I talked to the guy over the phone he said something about plates or bolts I would also need to purchase for the allignment to be correct. Do I really need to purchase this extra stuff? Or is the kit good enough alone?
Old Jul 21, 2008 | 01:06 PM
So_Cali's Avatar
So_Cali
Default RE: Quick Eibach prokit lowering spring question
You'll be ok without them, the Sportlines are another story, you'll runinto problems there alignment wise.I have the Pro-Kit and dont have any issues so far.
Old Jul 21, 2008 | 01:08 PM
SlinkyBMX's Avatar
SlinkyBMX
Thanks for the info!
Old Jul 21, 2008 | 02:58 PM
BaDStAnGT's Avatar
BaDStAnGT
i have asked this question before and many have told me that you most probably can get away
without putting all that stuff in, you can add them later on down the road
Old Jul 21, 2008 | 08:15 PM
owero01's Avatar
owero01
I have had the Pro Kit for over a year and haven't had any problems with alignment. The bolts they are talking about are for camber adjustment and you don't need them.
Old Jul 21, 2008 | 09:03 PM
BeachBlv's Avatar
BeachBlv
slinky is that your T/A in your avatar?
Old Jul 21, 2008 | 09:10 PM
howarmat's Avatar
howarmat
s197 Junkie
they are camber bolts.....sometimes you need them and other times you might be fine. They are only $35 and its better to have them on hand if needed than to not have them, need them, and then be replacing tires 5k later because your camber was screwed up. I didnt put mine on with stock shocks and stuts but it was needed when i put the dspecs in and then aligned.
Old Jul 21, 2008 | 09:35 PM
Stoenr's Avatar
Stoenr
ORIGINAL: howarmat
Exactly.
I needed a bolt on one side only, the camber was out of spec after the drop. The other side was just in spec by a degree, right where I wanted it. So I used the 1 camber bolt to bring the other side in spec to where I wanted it.
Old Jul 21, 2008 | 09:42 PM
Vader GT's Avatar
Vader GT
I bought the bolts initially & then switch them out with the Steeda heavy duty upper strut mounts that are adjustable. My alignment was off in the front before I did this. I have the bolts lying around some where if you need them, PM me.
Mike
Old Jul 21, 2008 | 09:46 PM
Stoenr's Avatar
Stoenr
And if you buy them locally, say like napa, and dont use them, you can return them.
