help diagnose problem
Old Aug 17, 2008 | 05:54 PM
mac10chap's Avatar
mac10chap
Question help diagnose problem
whenever i cold-start my car, it idles fine around 1000RPM's for about 30 seconds. if i let it sit any longer than that, the RPM's drop to around 500. at that point, when i give it gas, it stutters quite a bit. once the car warms up, it runs fine.
i have also noticed that as soon as the RPM's drop to 500, it begins to emit a white-ish smoke exhaust.
this has been going on for a couple weeks now
newest mods: Brenspeed tune about 3 months ago
Zex nitrous kit for about a week or so
i have not thrown any codes so i have no clue where to start with the diagnosis.
Old Aug 17, 2008 | 07:36 PM
mpatilla's Avatar
mpatilla
500 rpm is too low, I think. It should probably idle at 750. How many miles on your car? Have you replaced fuel filter?
Old Aug 17, 2008 | 08:10 PM
illin's Avatar
illin
Go back to stock tune and baseline. If it vanishes, call your tuner with your results on his tune.
Old Aug 17, 2008 | 08:20 PM
hammeron's Avatar
hammeron
i wonder if coolant is getting
into the combustion chamber(s)
would a compression test help
in this instance
Old Aug 17, 2008 | 09:24 PM
thewarmachine's Avatar
thewarmachine
Mine idles at 850.
Old Aug 17, 2008 | 09:30 PM
mac10chap's Avatar
mac10chap
well, like i said, it normally idle's around 1000ish. actually a little lower.
the problem only comes when it sits and idles for more than about 30 seconds. then it suddenly drops to around 500.
i havent replaced the fuel filter in about 40,000 miles. the car just rolled over 70,000. i think i am gonna try that this week and see if it fixes it. i have been planning on it anyways cause it is about due.
muffler bearings??? explain please...
Old Aug 18, 2008 | 08:36 PM
thewarmachine
Muffler bearings is a joke.
Radio coolant is another.
You don't have a vacuum hose off like I did, do you? I took off my air intake hose and forgot to reconnect the vacuum line when I put it back on. The rpms would really take a dive and then shoot up and then dive and then shoot up. ...especially when coming to a stop.
Old Aug 18, 2008 | 09:29 PM
Twiztga's Avatar
Twiztga
Last time I had an issue like yours it was my MAF sensor had oil on it from an over oiled K&N on the '00. I used some contact cleaner and cleaned it and problem was gone.
Edit: and when it bogged; it felt like it was gonna die then jumped back up to 1200ish and fell normal... was very strange.
Old Aug 18, 2008 | 09:40 PM
Hufenstang's Avatar
Hufenstang
same here i had a problem like this and i cleaned my TB and maf and the problem went away
Old Aug 19, 2008 | 03:02 PM
mac10chap's Avatar
mac10chap
yeah, i kinda figured that...like blinker fluid huh?? haha.
i dont have any vacuum lines loose, i've checked those. i have not cleaned the MAF sensor in a while and have recharged the air filter a few times since the last cleaning. i'll try that too. still banking on the fuel filter though
