Our harness wire size?
Old Aug 22, 2008 | 03:54 PM
Boozshey's Avatar
Boozshey
Default Our harness wire size?
What gauge of wire is our harness made from?
Old Aug 22, 2008 | 05:24 PM
jwog666's Avatar
jwog666
it depends on the circuit
Old Aug 22, 2008 | 05:27 PM
Boozshey's Avatar
Boozshey
If there are more than 1 size going to the PCM what would the sizes be, and what size going to the coil overs...
Old Aug 22, 2008 | 05:36 PM
jwog666's Avatar
jwog666
i believe that the wires from the pcm are 12 or 14 guage
Old Aug 23, 2008 | 10:53 AM
157dB's Avatar
157dB
Cut & Paste Expert
On a 4.6L?
Are you baiting me Boozy?
The wire size is dependent on the fuse protecting the
circuit and the amperage draw of the circuit.
Are you needing to know this for some specific reason?
Do you have electric coil overs on your front end?
My S197 does not have electric coil overs. Just plain ol struts.
Old Aug 23, 2008 | 04:22 PM
Boozshey's Avatar
Boozshey
Yup, looking into a wire tuck... More to come on that...
Old Aug 23, 2008 | 04:27 PM
157dB's Avatar
157dB
Cut & Paste Expert
I would get a junkyard S197 PCM harness and
use that to extend the OEM harness.
Quick and neat. No need to figure out what guage the wires are.
Old Aug 23, 2008 | 04:31 PM
Boozshey's Avatar
Boozshey
How much do they run though?
Old Aug 23, 2008 | 05:59 PM
157dB's Avatar
157dB
Cut & Paste Expert
Not sure.
Just use a wire one size bigger than the one you are lengthening.
And for gods sake, use the 2 stage adhesive heatshrink on those
soldered connections.
Old Aug 23, 2008 | 07:40 PM
Boozshey's Avatar
Boozshey
The ones I found are over $200.00. Not looking to spend that much. So I will just size up the wire as I go.
I couldn't get the manual to load on my laptop so I will try it on another computer later.
Solder and hear shrink??? Who said anything about that. Butt connectors here....
LOL, J/K...
Why do you say to use one size bigger?
