Need someone to help me
Can someone check something for me? My A/C clutch isn't coming on, so I've checked everything that could be blown, and can't find a thing. I've pulled the 2-wire harness off of the clutch, and neither of the wires are getting voltage when i turn the A/C on. One wire is black, the other is Pink with a blue stripe. Can someone tell me if one of these should be getting power? I assume it's the pink one. I'm not sure how else it would know when to kick on. Anyways, it's easy to access from under the car, so if nobody knows, can someone check theirs? Thanks
thanks guys. fuses, diodes, and relays are all functioning properly. I understand that loss of pressure would prevent that, but wouldn't the compressor still get power to it when i turn on the A/C? Neither of the wires ever get power to them, and it seems pressure or not one of them should get power to activate the clutch. So frustrating. I do not want to take this to Ford to fix.
You don't want the A/C to run with low pressure because it
will destroy the compressor. You can get a test gage at any
auto parts store to check it yourself, some may test for free.
The pressure switch is next to ABS box on line that runs
to coil infront of radiator, drivers side front.
